Cold idle too high???
Old Aug 31, 2006 | 04:46 PM
Flash319's Avatar
My cold idle seems to be very high and was wondering what everone else has for a cold idle. This is on a 22RE. When I first start the truck it idles at 2200 or so then comes down as it warms up. This is at about 15C. It idles great when warm at about 800rpm. I checked my throttle plate and the adjustment screw is not holding the throttle open at all.
Anyone else have this high of an idle?
Old Aug 31, 2006 | 06:43 PM
javadoody's Avatar
1500 tops, maybe slightly more in the coldest of weather out here.
Old Sep 1, 2006 | 02:58 AM
Flash319's Avatar
Anyone with any ideas as to why so high. My TPS is set fine, same with timing.
Old Sep 1, 2006 | 03:05 PM
84sr5yoty's Avatar
That's fairly normal RPM for a cold fast idle on the newer 22re's. I know the older air valves on the 22re's are adjustable, not sure on the newer ones though. Maybe someone will chime in here.
Old Sep 1, 2006 | 05:15 PM
javadoody's Avatar
carbon build up in throttle body (preventing plate from freely moving), vacuum leak, tps adjustment?
Old Sep 13, 2006 | 09:41 AM
Rustybronco's Avatar
Mine has the exact same problem!! '90 model 4x4. Anyone else have any other ideas?
Old Sep 13, 2006 | 09:55 AM
dcg9381's Avatar
VSV working and adjustment valve functional? Sometimes they stick and cause funky idle conditions.
Old Sep 13, 2006 | 10:21 AM
jjrgr21's Avatar
after about 150k miles on my 3.4 taco, it started to idle high, then calm as it got warmer, it had 200k miles when i traded it, it never bothered me, never leaked, or burned oil, got about 20mpg still. but i don't know what caused it.
Old Sep 13, 2006 | 10:26 AM
Flash319's Avatar
I had another intake so I took the high speed unit apart. It is very simple just a plunger with a spring. Coolent runs behind it an must heat up a plate that pushed the plunger closed. The truck idle does come down as it warms up so I can't see how this could be it. Maybe this is just normal. Very high for my liking though.
Old Sep 13, 2006 | 12:02 PM
Mine doesn't have a tach but to high for my liking also.
tomczaksdiesel
Jul 26, 2015 10:35 PM
Cbr954ryder
Jul 25, 2015 06:32 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
ZONAYODA
Jul 13, 2015 07:17 PM
