Cold Air/Supra AFM Mount (dial-up beware)
Old Feb 23, 2011 | 02:06 PM
  #61
jakestolar's Avatar
Originally Posted by shaeff
If you're just looking to do the battery/intake swap, you can do that for about $10 in extended battery cables. That's the only thing I bought while doing mine.
No, I am actually missing a pat of my AFM So I need to track it down...
Old Feb 23, 2011 | 03:12 PM
  #62
shaeff's Avatar
Oh, I see. In that case, as mentioned above, the junkyard will probably be your best bet.
Old Feb 23, 2011 | 04:50 PM
  #63
jakestolar's Avatar
yeah, Kinda sucks tho. I dunno if I can get that plate with out the AFM
Old Feb 23, 2011 | 04:55 PM
  #64
jakestolar's Avatar
Hey while I am on the topic, Does anyone know the make of supra the AFM comes off of? Meaning supra/celica celica gt ect ect
Old Feb 23, 2011 | 05:21 PM
  #65
myyota's Avatar
You can also find the adaptor you need on ebay, but try and find an original one from a junk yard, it will be better quality.
Old Feb 23, 2011 | 08:44 PM
  #66
irab88's Avatar
1982 supra. that's the only year that will fit. the last 5 digits of the part will be 43110
Old Feb 24, 2011 | 02:01 AM
  #67
myyota's Avatar
The AFM on mid 80`s cressidas is the same as the supra, that`s what i have on my 4Runner and its plug and play. Part # 22250-43110.
Old Feb 24, 2011 | 02:34 PM
  #68
jakestolar's Avatar
I understand the correct part number. I am trying to find out what model of the car they came off of. So that I can track down missing parts over the phone
Old Feb 24, 2011 | 04:59 PM
  #69
myyota's Avatar
You can find the part you need on supras, mid 80`s cressidas, and possibly camry`s.
Old Feb 24, 2011 | 06:45 PM
  #70
kmcmahon93's Avatar
what is the point of swapping the supra afm?
Old Feb 24, 2011 | 08:37 PM
  #71
irab88's Avatar
much larger afm, with plug-and-play. more air flow to the engine
Old Feb 24, 2011 | 09:45 PM
  #72
Philbert's Avatar
Chicks dig it.
Old Feb 25, 2011 | 09:41 AM
  #73
kiyobrown's Avatar
Originally Posted by Philbert
Chicks dig it.
we have a winner!!!!
Old Feb 25, 2011 | 01:19 PM
  #74
Junkers88's Avatar
Larger bore, more air, better throttle response with some exhaust mods and you can do dumb intake mods for fun. (see pics)
Old Feb 25, 2011 | 02:36 PM
  #75
1styota4X4's Avatar
i thought about moving my air box to that duct as well...Do you get more noise in the cab?
Old Feb 26, 2011 | 09:20 PM
  #76
skoti89's Avatar
Originally Posted by irab88
you mean the rectangle plate with the 3" tube sticking out that bolts onto the afm? it came with it. if your's didn't come with it, i think autozone might have something that could possibly fit, maybe. or hit up your junkyard again and find one that will work.
oh, and if i have any recent activity, i'll most likely respond. no problem
great! however, if you plan on doing the battery/intake swap, don't do this. save your money and time. it cost me about $60-ish for the swap, and in retrospect, should not have done this. but it was a good first project, and if it's all you need, go for it!
why do you say this? can you not do the supra mod and the swap? I was thinking of doing both with a kind of snorkel up the passenger fender
Old Feb 26, 2011 | 09:36 PM
  #77
irab88's Avatar
here is my battery-intake swap with the supra afm. the stock air box will not work with the over-sized supra afm. therefore, you need to use a cone filter.
the reason i said not to do this was it was in reference to the silicone elbow and aluminum pipe. while it does work, and i was happy with it, i ended up doing the swap. i spent time and money on something temporary. if you don't want to do the swap, then i would recommend it. i helped xlaxx out by installing my old set-up in his rig. since i had all the pieces cut with all the hardware, it was 100% bolt-in. he wasn't going to do the swap, and he's happy with just the cold-air set-up. i'm happy with the swap. all preference
Old Feb 6, 2012 | 08:08 PM
  #78
YotaNewbie94's Avatar
sorry to bring this thread back up, but it came across my mind to take a picture of my dilemma. the a/c hoses stick up way too high for a flex hose to go over them
just throwing that out there. if anyone has suggestions or ideas...
First post, so forgive me for the question if its been mentioned before. In your above picture you have a smaller filter on what, if I remember correctly, Toyota calls an "intake silencer" ? I also saw, in your battery/intake swap thread, that you had removed that part. My question is, does it affect anything when you remove that piece ? And do you half to block its connection point off ? I'm doing the mod this weekend & would like to do away with the very same part you removed,
Old Feb 7, 2012 | 04:11 AM
  #79
irab88's Avatar
it's part of the pair system, so with my truck having to go through emissions, i let it breath (cleaner burning exhaust). if you don't have emissions, you can remove all those parts you want and block off anything in that system. easy way is to just block off that hose at the source with a cap, suggested is an egr block plate set.
the intake silencer is almost necessary if you leave the system intact; it's really annoying without it.
mtb_taco
Oct 5, 2015 04:36 PM
crashburnoveride
Aug 28, 2015 09:20 PM
msged2007
Aug 22, 2015 07:46 PM
Sidherish
Aug 2, 2015 01:42 PM
ty1er
Jul 19, 2015 06:42 PM
