Clutch slipping like crazy
Old Feb 13, 2007 | 07:36 AM
Airedog's Avatar
Hey all, I've been away from the forum and my 4Runner for quite a while. I bought a diesel Golf 3 years ago and have mainly been using my 'Runner ('95, 5-speed, 3.0) as a work truck hauling gear at our outdoor ed. center. Last month I was pulling a small utility trailer full of firewood and noticed the clutch slipping as I climbed a hill on the highway.
Today it was 0?F with the N'or Easter on the way, and instead of taking the Golf to work I decided I'd take my truck. I could not even get up the small hill leaving my village is in without the clutch slipping. I turned around an went home for the frozen V-dub.
Where should I start? What should I check (not until next week, as we're due for 2+ feet of snow tonight into tomorrow) as far as hydraulics? I will check the fluid level and look for leaks, but aside from that...what? This clutch is not adjustable, correct?
I'm pretty bummed, I have a brand new set of BFGs on it and was really hoping to play in the snow.
Thanks all.
_____________
Old Feb 13, 2007 | 08:12 AM
gaboonviper85's Avatar
The only thing adjustable is the pedal travel...it sounds to that you just need a new clutch or your pressure plate is shot! time to buy a new clutch!
Old Feb 13, 2007 | 08:13 AM
it has nothing to do with fluid levels or leaks or anything other then the clutch its self....
Old Feb 13, 2007 | 08:19 AM
drew303's Avatar
Slippage comes down to just the clutch.
New clutches (OE) are around $185 if you do it yourself.
Old Feb 13, 2007 | 08:26 AM
Airedog's Avatar
That's what I was afraid of...
I guess I have not put any (or very much) money into it lately. I've got a leaky sending unit on the gas tank that has a "good enough for now, it doesn't leak" repair on it. Now to find someone I can trust for the clutch...
Old Feb 13, 2007 | 08:45 AM
i dont think there really is a wrong way to install a clutch unless you have a removable bell houseing that needs to be reindicated in.....just get a clutch you want and take it to someone you want to install it....you really cant go wrong.
pickle6415
Apr 14, 2021 06:20 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
scheuvront1993
Sep 17, 2015 06:17 PM
