clutch adj please help!!!!!!!
Old Jan 19, 2008 | 09:15 PM
just a 22re's Avatar
bump bump still need this fixed as we got lots of snow and 2wd isn't cuttin it anymore i need my 4wd!!!
Old Jan 19, 2008 | 09:19 PM
muddpigg's Avatar
Originally Posted by thook
My pedal was way too high when I installed my new MC recently. I adjusted the pedal height and now it's perfect.
Run this procedure down and measure everything.
http://personal.utulsa.edu/~nathan-b.../2checkand.pdf
It's kind of a chore, but this really covers everything you're dealing with.
No...you do not need to grind anything.
You rock, been bugging me for a year.
Old Jan 20, 2008 | 10:38 AM
thook's Avatar
Eghhhh....got the measurements on the my clutch push rod last night, but they're out in the car. I can get them today.
Sorry to keep you waiting, Allan.
Muddpigg...
The FSM is handy thing.
Old Jan 20, 2008 | 11:11 AM
Flash319's Avatar
Sounds like your slave cylinder is stuck or the clutch fork was not adjusted right when the trans/clutch was put together.
Old Jan 20, 2008 | 12:03 PM
  #25
thook's Avatar
Clutch fork adjustment?
Allan,
The measurements from the rubber boot to the rod adjuster is 1 7/8" with 1/2" of exposed threading. I don't know if that's going to make any difference as Flash319 has a point.
Old Jan 20, 2008 | 02:50 PM
  #26
ok when i put the motor back in everything was ok good to go pedal was at about 2 and a quarter inch from the floor everythings good installed new mc and sc and now its right at the top is there any yotatechers from the appleton bear creek fox cities greenbay waupaca co??? anything and ill meet up and show someone and they can help with this its hard to say pedal is at the top NO free play ill take a short crapy movie and post it or try ok but it will be on later tonight guy and gals
Old Jan 20, 2008 | 09:37 PM
  #27
clutch fork????? anyways heres an update i just drover her again and get this i pushed the clutch in to shift and she like got stuck in neutral nothing i could shift gears and i didnt even have my foot on the clutch at all then i pushed it and there was no pedal at all nothing so i pumped it again and bingo she came back you think my sc is sticking?? well heres a video of it sorry for it being dark but i tried guys and gals hope it help everyone understaind cause im brain lossed here
http://www.youtube.com/watch?v=-gPyZZ9kaQE
Old Jan 21, 2008 | 09:59 AM
  #28
thook's Avatar
You should title the video "The Blair Clutch Project"...
It's really hard to tell anything from the video. It is dark. Your motor sounds great, though!
Seriously....
Is the pedal height 6" or 2 1/4"? I'm a little confused over the first post on this page and the last one on the first. I'm assuming you meant the release point is 2 1/4"?
Regardless, the pedal being hard to move or not moving could mean two things. Either the push rod is not going in far enough or not at all (i.e. the MC is sticking) or the SC is not moving far enough or sticking.
You sure you installed the clutch pressure plate right? The release bearing?
Old Jan 21, 2008 | 10:02 AM
  #29
thook's Avatar
Or did you mean the push rod length is 2 1/4"?
Old Jan 21, 2008 | 10:42 AM
  #30
no the throw from free rolling truck to full grabing clutch is only 2 and a half inches the clutch is fine was real nice with old master and slave put new ones on and all hell broke out and i think one of them are sticking or my buddy said there might still be air in it some where is that true?
Old Jan 21, 2008 | 10:52 AM
  #31
thook's Avatar
Oh hell yes. If there's air in the line, it doesn't push the slave cylinder out all the way...and, consequently, the clutch fork/release bearing. That would esth'plain it.... Check it out.
Incidentally, the air is one of the things mentioned in the troubleshooting. guide.
Old Jan 21, 2008 | 11:18 AM
  #32
so you think air in the lines or something will have me nave a very very high pedal and im just waiting for youtube to load my video and i got a new one for you all it done in thre day so its clear and everything
Old Jan 21, 2008 | 11:19 AM
  #33
heres the video i gotta go thanks for all your help everyone!!!
http://www.youtube.com/watch?v=d3Iy_PWT6O0
Old Jan 21, 2008 | 12:55 PM
  #34
thook's Avatar
We need to get on the same page with terminology, I think...
High pedal? Do you mean "pedal height" from the floor or clutch "engagement point"?
I have to go take care of some things. Let me study the video (much better, btw) and reveiw the thread, but I'm thinking you just need to play with the pedal height adjustment or bleed the system again....if there's air, that is.
Later, skater...
Old Jan 21, 2008 | 12:59 PM
  #35
thook's Avatar
Okay....just took me a second to think about it. It "appears" to me that you're dealing with thing same I did. As I said originally, I had to adjust the pedal height at the adjuster. Bleed your line again. If that doesn't help, play with the adjustment. If that doesn't help, you need to study the push rod.
You never said if you still had your old MC. Do you?
Old Jan 21, 2008 | 04:27 PM
  #36
yes i still have both the old master and slave yet
Old Jan 21, 2008 | 04:28 PM
  #37
should i put the old slave back in and see if that will help out any??? cause i think the new one is sticking not letting the clutch to go all the way (full grab)
Old Jan 21, 2008 | 09:14 PM
  #38
ok its fixed i think now i rebleed it and well my finger slipped(hold thumb over hole with bleeder open when pumping an old techs trick) and sucked in a little air she golden now starts to ingage about 2.5 inches from floor and goes al the way to about 1 inch from the top perfect!!!!!!
Old Jan 21, 2008 | 10:22 PM
  #39
thook's Avatar
Way cool. Glad you got it, Allan. Now you're going to be really bored. Nothin' else to do...hahaha!
Well, except take more pics...lol.
Old Jan 22, 2008 | 08:15 AM
  #40
yeah lots of pics but my running lights take a long time to turn on when its cold to i dont get that unless the relay is slow
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
