check engine light help . . .please
I have a 94 toyota 4runner 6cylinder 4WD that has a check engine light on. I initially just changed the o2 sensor but later found out that there was an EGR valve fault. I then changed that too. Before I changed the EGR valve, the light would stay on constantly but now the check engine light comes on and off about ever 20-30 miles. It is currently still on now . . . any thoughts or suggestions?
My check engine light came on last Night. I Coded it to be "If Possible"...
25
26
51
Can you have 3 Different Codes? in one Setting? The Truck is Getting bad Fuel Mileage about 13 MPG and the Exhaust is in Pretty bad Shape. Any Ideas???
I Changed the Air Filter This Morning and Reset the Light.
25
26
51
Yes. You can have multiple codes. It is 'possible' that some codes are 'old',, that is - they weren't cleared out after a previous problem was repaired ( or not repaired).
Here are the codes and their sources:
25
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
____________________________________
26
AIR/FUEL RATIO RICH INDICATOR
--SAME AS ABOVE
--COLD START INJECTOR
_________________________________________
51
SWITCH SIGNALS
IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
--A/C SWITCH/CIRCUIT
--A/C AMPLIFIER
--TPS/CIRCUIT
--NEUTRAL START SWITCH/CIRCUIT
--ECU
25
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--IGNITION
--ECU
26
--SAME AS ABOVE
51
SWITCH SIGNALS
--A/C AMPLIFIER
--TPS/CIRCUIT
--ECU
Thank You for Your Help Guys! I Think I will Start With Getting the Exhaust Repaired And a New O2 Sensor. Truck Really does Seem to Run Fine other then the Loud Exhaust. I have Drove it almost 300 Miles in 2 Days and it Seems to Run better every Time I Drive it.
Thank you Guys
Dax
Thank you Guys
Dax
Dmatter- I have just encountered the same 3 codes: 25, 26 & 51 out of the blue at the same time ('89 4 Runner).
I was wondering what you have had to do to get rid of them?
From the descriptions 'regularguy' gave us, it seems like you wouldn't expect to get both 25 & 26 at the same time.
My A/C hasn't worked for years, so 51 has to be something else and I hope it's not the stupid ECU.
Jun 1, 2021 01:51 PM
