cant remove turbo from exhaust manifold
Old Jun 4, 2009 | 07:21 AM
bwells's Avatar
in my 87 turbo, i need to fix an exhaust leak between the turbo and the manifold. Unfortunately I cant unscrew the turbo from the exhaust, the nuts just wont budge. Do I need to let the vehicle run to get it hot first or what…
Old Jun 4, 2009 | 09:40 AM
aviator's Avatar
OK mr wells I fixed your stealth post so folks can see it... fyi don't select black as a colour when you are posting the default screen colour is black also so no one will be able to read it... if you just type it will show up as white on the screen when you post... if you need to use a colour for your screen setting try yellow/orange they will show up well also...
Letting it run for a bit would be one way to heat it up but then the turbo housing will get hot as well which might make it hard to work with... you could use a torch to provide spot heat which would help to loosen the bolts but be careful too much heat might lead to warping...
also try some lubricants like WD40 or LPS2 or a similar product.
oh and welcome to the family
Old Jun 4, 2009 | 09:56 AM
mrmatson's Avatar
I'd suggest PB Blaster in ample quantities and some time to let it soak in.
Old Jun 4, 2009 | 10:05 AM
DeathCougar's Avatar
PB Blaster (or similar) is going to be your best bet. WD-40 is useless.
Sometimes, things are just too rusted and your best efforts just won't get them. Try the spot heating method, with the PB Blaster, add some leverage, and it should pop loose.
Old Jun 4, 2009 | 07:19 PM
Dirt Driver's Avatar
Soak the fasteners with Liquid Wrench or similar for a while or just buckle down and be prepared to break/replace them.
Old Jun 5, 2009 | 09:24 AM
bwells's Avatar
yeah i just picked up some liquid plumer. looked for pb blaster but wal mart didnt have any. hopefully i wont have to replace anything and come out of the wallet even more
Old Jun 6, 2009 | 08:03 AM
bwells's Avatar
liquid wrench worked great. all nuts came off relitivly easy. now i just got to figure out how to slide the manifold to the side off the engine and up off the turbo at the same time
Old Jun 6, 2009 | 03:47 PM
aviator's Avatar
Liquid Plumbr is for getting clogs outta drains... not sure how well it would work on seized hardware... lol... I think those mental giants working [slaving] for mr. sam's relatives goofed...
Old Jun 7, 2009 | 04:03 PM
bwells's Avatar
my bad, i meant liquid wrench.....
Old Jun 7, 2009 | 06:54 PM
iamsuperbleeder's Avatar
haha, but he has no clogs in his down-pipe after the turbo now for sure
Old Jun 7, 2009 | 08:00 PM
aviator's Avatar
I bet his intake runners are nice and clear too...
God's Bounty Hunter
Oct 23, 2015 09:44 AM
RatOmeter
Oct 22, 2015 03:17 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
