can someone explain how to unhook the vamf?
Old Jul 26, 2013 | 07:16 PM
ghostgxz's Avatar
On a 93 2wd 4runner with 3vze, can someone explain how to remove the connector to the vamf, it seems like there is a little button on the underside that you have to push in in order for it to come unplugged when pulled, but it wont come off
Old Jul 26, 2013 | 07:19 PM
j2the-e's Avatar
You have to disengage the wire clip on the sides
Old Jul 26, 2013 | 08:41 PM
Edionne13's Avatar
Don't loose the wire clip I broke my vafm while trying to get it off don't try to force it off
Old Jul 26, 2013 | 09:22 PM
ghostgxz's Avatar
ok i managed to get it off, you have to push the wire clip outwards on each side
now can someone help me find out where online to get a new vamf?
(i tested it and one of the steps the ohm range should be between 100 and 300 ohms, it measured 0.000)
Old Jul 26, 2013 | 09:34 PM
Gamefreakgc's Avatar
Best bang for your buck is to grab one from a junk yard. Most have return policies too.
If not... you're stuck paying $200ish from somewhere like Autozone, or more from the dealer.
If you're feeling adventurous, might I tempt you with a 7MGE AFM from a Supra or Cressida... it's a bit more work to make it fit though.
Old Jul 27, 2013 | 07:52 AM
scope103's Avatar
$130 + at RockAuto.
If you try the junk yard route, be sure to take your meter with you.
For $130, I'd consider trying to repair it. Just don't forget that RockAuto and Autozone have core charges, so factor that in -- the VAF is sealed, and if I was a dealer I wouldn't take a core that had been opened.
Old Jul 27, 2013 | 05:06 PM
ghostgxz's Avatar
thanks to everyone who responded , will let you know what happens next
Old Jul 27, 2013 | 08:13 PM
Edionne13's Avatar
You can order one off o' Riley's website pretty cheap considering other auto stores
Old Jul 27, 2013 | 11:45 PM
ghostgxz's Avatar
Hmmm, i checked oreillys before and wasnt able to find it there, ill check again
beltcutter
Sep 30, 2015 06:14 AM
mulewright
Sep 28, 2015 10:27 AM
potatopants
Sep 15, 2015 06:26 AM
toyotafreak98
Sep 10, 2015 02:57 PM
