Camshafts not aligned?
Old Apr 9, 2007 | 09:51 AM
VoxMan's Avatar
Am trying to finish up after replacing my blown HG's on my 3.0. When I was about to check valve clearance with the crank set at 0TDC I noticed that the two timing marks on the camshafts don't line up with each other or with the mark on the crank pulley. The driver side cam has the timing mark pointing straight up, while the pass. side points toward the outside of the engine bay. Should they both line up at the 12 o'clock position? I'll attach some pics. Thanks for any help
Attached Thumbnails Camshafts not aligned?-d-side-cam.jpg   Camshafts not aligned?-p-side-cam.jpg
Old Apr 9, 2007 | 01:57 PM
ChickenLover's Avatar
Without the belt, they won't stay at the 12 o'clock position. Because of the shape of the lobes, the cam will likely flop over when you remove the belt. You don't need to worry about lining them up until you are putting on the belt.
Old Apr 9, 2007 | 02:21 PM
VoxMan's Avatar
Thanks ChickenLover! You've saved me from some un-needed re-bolting.
Old Apr 9, 2007 | 07:12 PM
toyota_mdt_tech's Avatar
Both will be straight up 12 oclock. The pass side cam will want to go right to straight up, while the drivers side will go there, but with vavle spring p ressure. Once you get the tin on, you will see the marks. Dont forget, each cam gear goes on different, drivers side is flipped so the flange is out, pass side, flange is in.
Old Apr 9, 2007 | 07:58 PM
Bumpin' Yota's Avatar
mdt - why are the gears flip flopped like that to maintain timing belt alignment?
Old Apr 10, 2007 | 08:27 AM
benwahballs's Avatar
isn't it just so that the timing belt can't slide off?
btw hows your truck runnin bumpin?
Old Apr 10, 2007 | 08:33 AM
TNRabbit's Avatar
[quote=benwahballs;50496783]isn't it just so that the timing belt can't slide off? /quote]
Correct.
Old Apr 10, 2007 | 04:26 PM
Stronger and faster than ever before. The passing gear is GREAT! 40 TO 60 in 7 seconds is a blast. Driving it around is even more fun than when it was stock. 0-60 is faster than any of the diesel swaps out there whose videos ive watched; just a hair over 11 seconds where stock trim had it doing it in 13.5 seconds or so.
There is NO pinging at all even at 13*btdc. I think im going to up the timing again to 15* and see how it runs. The oil leaks I had before are gone.
The few things that ARE bugging me are:
1. Low compression in #1 cyl (110 psi)
2. Check Valve clearances (could be causing #1)
3. TPS circuit fault
4. Leaking radiator
5. Squeeking alternator belt
Old Apr 10, 2007 | 10:51 PM
VoxMan's Avatar
Engine wire brackets
Can anyone tell me how to attach the engine wire brackets to the valve covers? do they go between the cylinder head and the cover or on top of the cover? I can't find a good picture of them in the fsm and I can't recall how they were before I took them off.
Old Apr 11, 2007 | 12:03 AM
TNRabbit's Avatar
Dude, they HAVE to go on TOP of the cover! It would leak if you put it between the head and the valve cover!
Old Apr 11, 2007 | 12:05 AM
TNRabbit's Avatar
Mine were the other way around when I pulled the timing cover off, passenger side was flange was out. Does it matter?
Old Apr 11, 2007 | 02:35 PM
Doesnt matter. Just keeps the belt from migratign too far in or out.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
voiddweller
Sep 28, 2015 11:21 PM
gyroscope7
Sep 21, 2015 04:55 AM
gyroscope7
Sep 13, 2015 05:15 AM
