A/C Techs Help Needed
Old Jul 6, 2007 | 08:31 PM
854x4's Avatar
First a little history the truck is a 86 toyota 22RE. I replaced the a/c pump 6 months ago along with the reciever drier, the old pump was bad plus it was low on freon. Had a shop recover and store the remaining freon and then put it back after I installed everything. It was still low so I put a can in and it was right in spec and really cold 40 degrees. Now 6 months later it only gets to 80 when its 110 outside. I checked the pressure and when I hook up the gauges both are at 150psi then I turn the compresser on and the low side is 40psi and the high side is 250psi.Its not low on freon so I dont know what the problem is? Also when the shop put the freon in the truck they didnt pull vacuum like they should of, but it was a family friend so you all know how that goes. I'm a a/c tech so I know a little about this but with my lack of a recovery machine leaves me stuck. My theory is there is air or moisture in the system. I plan to recover , vacuum and recharge with freeze 12 but I would like to get a second opinion? Thanks
Old Jul 6, 2007 | 10:52 PM
YodaPala's Avatar
Uh, the first problem is you re-used refrigerant that is usually a no-no. Yeah refrigerant doesent wear out, but it can be contaminated. personally I'd start over w/ some new refrigerant and make damn sure you pull a good vacuum on it, I'd try this first and see whacha ya got.
Old Jul 6, 2007 | 11:16 PM
854x4's Avatar
I know the refrigerant wasnt contaminated (original 1986)and it went through a recycler, but with the guy not pulling a vacuum its probaly contaminated now. R-12 stoped being produced around 1995 so all refrigerant now is mostly used and recycled.
Old Jul 7, 2007 | 04:52 AM
ssupercoolss's Avatar
so are you saying there was no vacuum put on the system after you installed the goodies? if so, you need to just start over.
Old Jul 8, 2007 | 05:02 PM
Bigblock's Avatar
What did you do with that antique expansion valve?
Old Jul 8, 2007 | 05:03 PM
854x4's Avatar
Expansion valve was never replaced
Old Jul 8, 2007 | 05:05 PM
Bigblock's Avatar
And the fan clutch?
Old Jul 8, 2007 | 05:15 PM
Bigblock's Avatar
While you're replacing the EV clean the evaporator inside and out.(spotless)40 degrees wont do.Does yours have a evap temp sensor?
Old Jul 8, 2007 | 07:41 PM
854x4's Avatar
The fan clutch seems to work its 110* here and the truck has never got hot. I dont think the truck has a evap temp sensor.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
mickyd9990
Jul 6, 2015 09:01 AM
