c clip front axle help!
Old Oct 10, 2007 | 04:45 PM
dcmbsc's Avatar
i am changeing my front axle and i have gotten to the point where i need to take the c clip off . i need a diagram , i cant get to the c clip , i need pix , help!
Old Oct 10, 2007 | 04:52 PM
thook's Avatar
Does this help?
http://personal.utulsa.edu/~nathan-b...onandaxle.html
EDIT: I suppose I should have asked...what seems to be the problem? Why can't you get to it?
Old Oct 10, 2007 | 04:56 PM
Tofer's Avatar
Sponsor
use a pair of needle nose pliers to open the clip and slide it off.
Old Oct 10, 2007 | 05:06 PM
tc's Avatar
tc
Or a screwdriver under one end and work it around until it's out of the groove.
Old Oct 10, 2007 | 05:34 PM
dcmbsc's Avatar
can you pull the cones out with a wheel puller, because they wont come out by hitting them?
Old Oct 10, 2007 | 05:42 PM
FredTJ's Avatar
How area you hitting them and with what ?
Fred
Old Oct 10, 2007 | 05:44 PM
dcmbsc's Avatar
i am hitting the stud with a brass rod
Old Oct 10, 2007 | 05:54 PM
FredTJ's Avatar
Try hitting the side of the flange itself.
Mine popped right off. No problem at all.
Fred
Old Oct 10, 2007 | 07:06 PM
dcmbsc's Avatar
it wont come out , i have to get a screw puller outter tomarrow
Old Oct 10, 2007 | 07:12 PM
4Crawler's Avatar
Cone washer removal tips:
http://www.4crawler.com/4x4/CheapTri...eWasherRemoval
Not sure which c-clip is being referred to, but some tips on the page above.
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Cabell
Jul 24, 2015 12:14 PM
