broke my timing chain guide, time to rebuild (pics)
Old May 4, 2011 | 05:22 AM
  #361
irab88's Avatar
nice. sounds great, thanks rb
Old May 6, 2011 | 09:03 AM
  #362
irab88's Avatar
update on the engine. after driving for a week, most of the noise has gone back to normal. there's still the exhaust leak and maybe some sort of mechanical sound, both of which i'll be checking out this weekend. also, i filled up today. ~21 mpg. sweet, back up to where i was before
Old May 6, 2011 | 09:05 AM
  #363
Lumpy's Avatar
Nice man! Good to hear that she's all better aside from a lil exhaust leak. The other sound may be the valves needing tweaked a bit.
Old May 6, 2011 | 09:10 AM
  #364
ChefYota4x4's Avatar
Just a tip... if you put a lil seafoam in there, just enough to get it to smoke, not for a treatment.... it will reveal where your exhaust leak is after it sits in there a minute and then you start it up. It revealed EVERY leak for me, lol. I had around 8 on my stock down pipe and 3 on the manifold itself. And mine has NOOOOOOO rust. However, I'll have to listen again, .....yours is a 'swooshing' leak,.... but it's got a lil 'tap' to it, so it might just be the exhaust manifold not seating somewhere, ya know? You'll find it, Ian, .... and GREAT to hear on the mileage, ....SHEEESH! lol. That's combined, 21?
Old May 6, 2011 | 09:16 AM
  #365
RBX's Avatar
RBX
^^^ or you cold hook up the fuel return line to a vacuum port and then start the engine,,,, you will quickly see ALL the leaks on your exhaust, highlighted by fuel.....don't ask how i know this, but it has to do with my ghetto rigged 3vz.
Old May 6, 2011 | 09:24 AM
  #366
irab88's Avatar
yeah, 21 combined, mostly on parkways (~50 mph with the occasional stoplight)
i think i have seafoam... hafta check
Old May 6, 2011 | 09:31 AM
  #367
xxxtreme22r's Avatar
Lol I've done that with a few drops of coolant in the intake/carb etc etc. works pretty well.
Old May 6, 2011 | 10:30 AM
  #368
irab88's Avatar
also got a tip that atf works
Old May 8, 2011 | 07:46 AM
  #369
Badger62811's Avatar
Awesome rebuild. I wish mine was going as good. I went to bed late last night working on it and after a couple hours sleep had to come in to work. Ugh. I was having problems getting the distributor at TDC. Saw some of your photos and some photos in another build that was posted here and I'll have to adjust it when I get home. I have a slight fuel leak from the big fuel line (19mm bolt) on the bottom of the intake. I'm pretty sure I just need to replace the washers. It runs (surprisingly) but it is really rough and was only idling at 500ish when it was first fired. Hoping getting the dist on there correct will fix this. If not, um.. yeah...
Old May 8, 2011 | 07:49 AM
  #370
Yep, that's what I said... Don't hold it against me I worked on it from 9am to 1am then got up at 4am and won't get back home and in bed till 9pm.
Old May 24, 2011 | 09:56 AM
  #371
irab88's Avatar
bit of an update on the rebuild: gas mileage
before: low 18 to high 19
after: mid 20 to high 21
Old Nov 2, 2011 | 12:45 AM
  #372
Rebel Lady's Avatar
Subscribed..
Old Dec 24, 2011 | 07:55 PM
  #373
blisters13's Avatar
I started this job yesterday. The truck is a '90 2WD manual trans. I was easily able to break the front crankshaft pulley bolt loose with a common 1/2" drive breaker bar and a 3/4" hex impact socket. I had the trans in 5th gear with the parking brake set tight; the crank didn't turn more than about 10 degrees before the bolt came loose. This was an original, undamaged bolt and the engine has 120,000 easy miles on it (previously owned by an old guy who doesn't flog his vehicles). A 19mm socket is not required- the 3/4" socket fits very well.
Old Mar 2, 2012 | 12:42 PM
  #374
2012MongolRally's Avatar
I'm glad I found your post, I recently bought a 93 Toyota Pickup and am using it for the Mongol Rally in July. Lots of useful info here, thanks chief.
Old Apr 22, 2012 | 03:16 PM
  #375
Jagman60's Avatar
In the photo of the valve cover, there are four sensors visable, a blue plug and a brown plug, then more towards the front of the engine is a brown and a gray plug. What are the brown and gray plugs for? and will the engine run if those are missing? In my truck those two plugs are not plugged in and the truck does not run. The sensors are missing. Hate to sound stupid but the engine was received in peices and it appears some stuff was missing.
Old Apr 22, 2012 | 03:38 PM
  #376
irab88's Avatar
all of those are vacuum valves for various emissions systems. every truck is different, so your's probably needs those to run correctly. look though a haynes manual to see if you can trace the vacuum lines and valves
Old Apr 22, 2012 | 04:15 PM
  #377
What year 22RE is it?
Here is a diagram for an 87 22RE w\AC (Mine)....
It lists both VSV's on my year.. But my 87 does NOT Have an EGR VSV nor others that later model rigs have. VERY important to know what year, because you might not be missing anything, depending on the year(If I missed you posting the year..... forgive me, I'll shut up now! hahaha)
Sorry Ian... just going through this right now, so thought I'd throw it up there..... Don't throw that wrench at me, k? hahaha
Old Jul 31, 2012 | 07:16 PM
  #378
luxdlx's Avatar
Nice write up. Thanks for all the good info.
Old May 8, 2013 | 05:37 PM
  #379
dakotawho's Avatar
Between your thread, 92 toy's, 4crawlers writeup, and the help(from yotatech) that will come if i run into a problem, this timing chaing/head gasket job isn't seeming so bad. Thanks for the writeup! I learned to get some head bolts early on!
Also was your head gasket from engnbldr?(Can't quite member)
Old May 8, 2013 | 06:03 PM
  #380
irab88's Avatar
nope. fel-pro from o'riely's auto. they had a decent price at the time, but fel-pro is a decent brand. 25k+ and my engine's running better than ever
