Brake problems
Brake problems
On my 86 I have had to add brake fluid two times in the last two months. I have checked all the wheel cylinders checked the lines and have not figured out where I am losing fluid at. Has anyone else had this problem?
NO NO NO NO NO NO NO theres a little gasket right between the two! and it leaks from there over time and yes it dont look like it cause when you filled it up you spilled right? this is what you do fill it take brake clean to the whole area to get it real clean! then go driving and after it goes low cheack it out oof with engine off jump on that brake peddal and get it to leak ie snaping the week link! and go from there everything is easy to fix on these yotas when it comes to brakes!
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
What he said was that there's a gasket between the MC and booster, clean that area good with brake clean, re-fill, and drive it for awhile, checking often to see where it's leaking.And with the engine off, step on the brake peddle a couples of times, to see/find the leak. It could be leaking on the inside of the cab, check the carpet on the driver's side by the peddles
First, you need to create an account at an online picture hosting site. I really like photobucket.com, as do others. It is free, so it won't cost anything but a few minutes of your time to create an account. Upload your photos to that site and then just copy and paste the IMG code into the body of the message. The IMG code is listed below the picture after you upload, so it is really easy.
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
