bouncing speedometer
Old Jun 10, 2009 | 04:53 PM
jacumja's Avatar
Should I grab some wet graphite film lubricant or will my can of Toyota Sillicone all purpose work. Then I just have to wait until its not 90 degrees outside, so I can stand to sit in my drive and get it done.
Old Jun 10, 2009 | 09:03 PM
88T4R's Avatar
I saw this thread ealrlier today and have needed to do this for a while and took about half hour and now the spedo barely bounces at all, mine was really bad at low speeds, but this works great to fix it.
Old Jun 11, 2009 | 05:33 AM
highway's Avatar
how long does it take you all to actually get lube into the cable? For me I can barely get any graphite down the cable and takes for ever ....is there a trick to it that i don't know about ?
highway
Old Jun 11, 2009 | 05:55 AM
ozziesironmanoffroad's Avatar
just keep goin with it. mine bounces at 60-65mph, but then it stops when i get past 65, or under 60. doesnt do it all the time, either. weird tho, brand new cable... oh well. just lube the heck out of it.
Old Jul 5, 2009 | 10:57 PM
  #25
jacumja's Avatar
Well with no tutorial and about a half an hour at dusk. I chose that time due to the break in 100 degree weather and no mosquito's due to beach breeze. I managed to locate and spray graphite in the connector of the speedo cable that supposedly didn't exist on my 95. I reconnected and went for a test drive. Nothing changed and I put out a call for help on here.
I really didn't see a way to grease the cable only the point within the connector as well as the outlet on the back of the cluster.
Frustrated I put it all back together, drank beer, played madden and when I left it worked. I guess it took time for it all to soak in or something but I now have a working speedo and working cruise control.
Thanks for all the help, I think I'm going to change all my dash led lights. I'm thinking I'll do a nice tutorial for people that have my trouble.
Old Aug 15, 2013 | 11:08 AM
  #26
Lomew Bartho's Avatar
Hey Guys well I think that everyone post appreciating post about the topic of bouncing speedometer. Thanks for providing that amazing stuff.
Old Aug 15, 2013 | 05:58 PM
  #27
cobolt23's Avatar
Just a heads up. NAPA carries the one for up to 92, as 93-94 were VSS, for $18.95. As for the 95? Well, after looking at the parts books, the number for the 95 is different then the older ones. But after looking one line down, the part has been disconntinued and replaced with a new part number, the same as the 95. So the older ones will fit in the 95.
Old Nov 1, 2014 | 02:34 PM
  #28
Trickstick80's Avatar
Speedo off after transfer case swap
I am also having problems with my speedo needle. I just swapped transfer cases, and now in first gear it reads around 60MPH. By the time i hit second, it's pegged. The transfer case i put in didn't come with the speedo gear, so i used the the one from the stock one.
Any ideas?
Davebarbier
Nov 3, 2015 03:28 PM
Phantez
Sep 30, 2015 08:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
83
Sep 27, 2015 04:13 PM
toyotafreak98
Sep 10, 2015 02:57 PM
