Best way to get a cam gear bolt torqued
Hello... I have a 1986 Pickup 22RE AT. Anybody have a trick to get the cam gear bolt torqued to 58lbs without a pulley holder? Is it bad for the engine to rotate at this point in a timing chain replacement?
The 3VZE cams have a 27mm flat in the middle of the cam. A 1 1/16" wrench will fit, but it's not hard to find a 27mm. Avoid an adjustable wrench; the don't want any part of the wrench to hit the aluminum head.
i put a bar thru one of the holes in the cam gear and held it while i torqued the bolt... rested it on something that wouldn't hurt the head or the value assembly..
sethn
Dec 16, 2010 10:11 AM
Erik Beeman
Aug 14, 2009 04:31 PM
bobzemuda
72
Apr 10, 2007 08:09 AM
Nix_Toy
Feb 26, 2006 04:48 PM
