Best place to drill through fire wall ??
Old Oct 15, 2007 | 04:20 PM
swerks's Avatar
Question Best place to drill through fire wall ??
I am trying to install my mechanical boost guage where would be the best spot to get through the fire wall??
Old Oct 15, 2007 | 04:24 PM
89macrunner's Avatar
if at all possible I would try going through an exsisting grommet in the firewall. If not. Make sure you find a place that is easily accessible from both the inside and out. Near where the steering column goes through the firewall maybe?
Make SURE you use a grommet,silicone, or whatever to seal up that hole!
Old Oct 15, 2007 | 04:31 PM
swerks's Avatar
any suggestions as to which existing gromet I might try???
Old Oct 15, 2007 | 04:33 PM
CJM's Avatar
CJM
Should be aload of wiring and a grommet that is right under the dash near the brake pedal already.
Old Oct 15, 2007 | 04:35 PM
n16ht5's Avatar
the grommet that has the tach wire and ECU harness running through it, on driver side. piece of cake. just take a screw driver and pry an openning, then stick a wire through
Old Oct 15, 2007 | 05:01 PM
Amacfarl's Avatar
don't drill!
with a little effort you should be able to squeeze the hose through an existing grommet. You're using a very thin plastic hose, right?
Old Oct 15, 2007 | 05:36 PM
jcfb's Avatar
Underneath the hood, right by the clutch MC and the hood hinge. Huge grommet. Just slice a hole in the side with a knife and run whatever you need.
Old Oct 16, 2007 | 02:37 PM
swerks's Avatar
This truck is automatic and I dont see any where that there is wires going through the fire wall except on the far passenger side ??
wberry85
Apr 6, 2018 08:45 AM
Marsheen
Feb 17, 2016 12:29 PM
gp66
Sep 7, 2015 08:29 AM
dguzzi
Sep 3, 2015 08:48 AM
