Best Junkyard Mods
Old Aug 23, 2010 | 08:12 AM
  #121
kiyobrown's Avatar
Yup. Switches are in better spots, better armrest. Check out pismojoe's 86 door panel swap. Good write up!
And Phil, I got a drivers side one (with vent!) from nix99, they might have a passenger side one for you. Just ask for Josh(deathcougar), and say you are from YT!
Old Aug 23, 2010 | 08:25 AM
  #122
Philbert's Avatar
Wow - never had heard of nix99 before - thanks!
I checked and they don't seem to have the part....will email/call them and see what I can do.
Old Aug 23, 2010 | 09:42 AM
  #123
irab88's Avatar
for the window motors, it looks like they have different resistance values (just a guess) judging by the "2k" and "7k" on the housings, just to the right of the "12v" marking. i think that might only affect what size fuse you put in, but then again, i'm not even sure if that's what the difference is
Old Aug 23, 2010 | 10:23 AM
  #124
kiyobrown's Avatar
I would call em. I know I bought the twin of what you are looking for, so they have had em run through their joint at least once. Power mirrors, almost never.
Old Aug 23, 2010 | 11:55 AM
  #125
Philbert's Avatar
Yeah so I called Josh over there and no dice....he can get me one new from Toyota for 10% off - $90 - ouch!
I'll keep searching eBay....
I also asked him about 88 door panels while on the phone.....no way jose :/
Old Aug 23, 2010 | 12:24 PM
  #126
DeathCougar's Avatar
Keep in mind that crap you can find on Ebay is cheap made, and most don't have the correct return spring in them Phil.
I have seen those aftermarket ones fail at astounding rates. $90/22 yrs isn't that bad of a deal
Old Aug 24, 2010 | 02:40 AM
  #127
Icathers's Avatar
every time i go to u pull it, there's never any toyota trucks. except for that rare occasion where they say "i just got one in an hour ago" and i take a look but by then there's only a frame left... actually the other day they had three, but they were all picked clean and the wrong years anyway... i need a power steering gear box!
Old Aug 24, 2010 | 01:42 PM
  #128
Philbert's Avatar
I know Just mad at myself for being young and dumb years ago and tossing out that rare piece.....ARGH!!
Old Aug 24, 2010 | 02:28 PM
  #129
Ron Helmuth's Avatar
just wanted to mention guys that Yoda Jim's lot here in Denver has lots of first and second gen Runners. I am not- repeat not- affiliated with them in any way- but seem to find myself there pretty regularly. If you specifically tell me what to get for you I can look at their selection or you can simply call them and deal with them.
4210 Jackson St Denver CO 80216 (303)506-5119
With regards to window motors just be aware that Dorman (see Amazon or ebay) manufactures replacement window motors and the only issue I had with them was they use a "ridge" surrounding the toothed gear that would have to be removed to allow the white plastic toothed gear to snap into place and rotate freely. (I believe the white plastic gear mates to corresponding teeth on the window regulator but honestly I barely understand this stuff myself...)
here is a link to a visual-see the black ridge surrounding the toothed gear?
http://www.amazon.com/Dorman-Solutio...2689135&sr=8-2
I am going through this now with my 89 MR2 and have had no luck finding actual working factory replacements for anything approaching affordable price. I am tempted to simply try a Dorman unit and cut away (angle grind maybe) the ridge. Having to splice in the correct electrical connector is quite likely and the last Dorman unit I saw came with 3 plug varieties to match up to.
This toothed gear would be on the reverse side of the Camry window motors pictured in post #111.
Last edited by Ron Helmuth; Aug 24, 2010 at 02:33 PM. Reason: attach a link for more clarity
Old Aug 24, 2010 | 03:39 PM
  #130
Philbert's Avatar
Thanks Ron - that's some great information!
If you come across a pickup/1st gen 4runner with power windows and the vent triangle window, I need the passenger side regulator
And if you fine 2 grey interior door panels from an 88 4runner, I'm your man!
Old Aug 24, 2010 | 05:47 PM
  #131
wii_tarded's Avatar
got my villager/quest e-fan today, didn't even have to unbolt it, it was just laying there. Got my entire interior out of a $200 truck, including driveshaft, rear window, and t-case. then sold the body for $100. found visors, center caps, steering wheels, assorted interior pieces. grille and headlight bezels....need a dipstick for a T-100 3.4L.
Old Aug 27, 2010 | 12:05 PM
  #132
se7enine's Avatar
Found these Bilstein shocks on a 4runner today at the local Pic N Pull, not bad for $30. Will be better then my stock ride is at the moment.
Old Aug 27, 2010 | 01:02 PM
  #133
irab88's Avatar
^^ not bad at all
Old Aug 27, 2010 | 01:09 PM
  #134
93yotaSR5's Avatar
wow nice pick.
Old Aug 27, 2010 | 05:21 PM
  #135
Teuf's Avatar
Nice. If they were Ranchos they would be rusted.
Old Aug 27, 2010 | 07:36 PM
  #136
alil2cul4u's Avatar
I was at a yard up here in Northern Greeley today and found an 87 P/U with a 22re-t. The odometer read 187,xxx or something like that. The engine was in very good condition, there wasn't anything missing off that motor! I also saw a 2nd gen 4runner 2 door.
Old Sep 26, 2010 | 08:40 AM
  #137
bone collector's Avatar
i just picked up a V6 master cylinder and power booster for my pickup. 30 bucks for the combo!!! i also got a stock speedo with the tach in it for another 20. not a bad days work...
Old Sep 26, 2010 | 10:29 AM
  #138
paynemw's Avatar
subscribed
Old Sep 26, 2010 | 03:26 PM
  #139
shawns88's Avatar
theres 3 yotas in my local junk yard, all 3 have the 3.slow in em and are 89 and newer. i got tires and rims and hole buncha stuff outa pick and pull that i dnt remember.
Old Sep 29, 2010 | 09:55 AM
  #140
RBX's Avatar
RBX
got the GM tow hooks right and left, not installed yet
extra courtesy light and deck light: Tailgate Courtesy Light Trigger Mod
Clinometer/Compass/temp/altimeter cluster from a '96 Montero...like this
Villager/Quest Fan, this Thread
Just off the top of my head...
