Best 22RE Intake!
#41
Hey, sorry for the late response. I usually browse this site when it gets cooler out. I'll snap some pics when I get a chance. Right now, I've got the bed off for rear frame painting, gas tank, and fuel feed line swap. Gotta finish that up ASAP, it's going to get cold soon!
Shoot me a PM in a week or two if I haven't updated this thread with pics yet.
#42
that setup looks very schwing!!! Most of what was said after that, I don't get; about moving it here and there for cold air, or mudding, etc., but on the first setup, if it improves mileage at all, I am all about that!
So if it comes with all parts necessary, and instructions for installation, I'll turn a wrench for it! What is an egr line, anyway?
#44
they have been making thermo gaskets for honda's for long
$24.99 one more thing to get for the efi swap!
time..http://www.precisionpowerparts.com/s...=0&i=134642226
#46
In theory wouldn't dry ice(yea you have to replace it all the time and it would cost a ass load but it would cool the incoming air a lot better it would seem) work in line somewhere work better for cooling the air then running the aluminum the same way the plastic intake tube is run because if I am not mistake aluminum will hold the heat longer then plastic anyway
#49
^^^^^^^ That is a perfect example! I think your double stack filter is to a 22r what my 2.75" intake tube is to a 22re. The drivability differences that you noticed with the extra air filter sound very similar to what I noticed when I switched to the 2.75" intake tube. I am fortunate enough to have access to a dynometer, and I wanted to share my results with the Toyota community. But like you pointed out, it is difficult to see the benefit of a better breathing intake just by looking at a dyno graph.
#50
yeah gona bring this back!!!
hey stold your idea ha
how much were your intake tubes???
and what you do with the egr hose???
also your hp power and torque R on the floor man
how many miles on your 22re
i was doing 135 torque and about 109 on hp
but i also noticed you opened up your exhaust bad idea to trade power for growl from your tailpipe
eh your truck...
heres some pics of mind
my Tb was aimed down word at an angle about 45 deg so this is what i did to get to it
The reason Y i did this was beacuse my 90 deg coupler ripped on me when i was offroading so this had no play in the couplings so hopefuly meaning no tears
let me know what you did with the egr hose
jose juan
eh your truck...
jose juan
#54
Guys it's an 88 so the TB is at an angle so I realy coud not figure a way to get to it so I did 45 deg cuts any Ideasi to improve this distortaion
plus I made it beacuse my coupler riped and well I was not going to spnd a bill or more for a new one
the welds yes Bad but first time welding
peach
peach
#57
peach
peach
#58
Even easier...relocate your battery and run your intake to the other side. Then you can keep the down angle as you have nothing to clear.
Unless the pipes are holding pressure (forced induction) there is no harm in grinding back welds. Even the worst welder in the world can make a seamless join with enough patience and grinding.
steve miller
Oct 10, 2015 01:40 AM
Tacoma1313
Aug 17, 2015 05:44 PM
