BEGINNER'S 22re Timing Chain Failure / replacement / head gasket replacement
Old Sep 4, 2011 | 05:52 PM
  #181
92 TOY's Avatar
thanks man.....makes it easy for me to go back and help others too.
Old Sep 5, 2011 | 06:34 AM
  #182
RAWRMON's Avatar
Originally Posted by 92 TOY
I got a request for pics of vac hose routing, so I figured I'd post them here for everyone to see and maybe help someone too.
I have plenty of pics and also it's as simple as I can go out and take a pic and post it up.
outstanding photo's if i need anymore i'll post a pic of the area... here's a pic of current setup so you can see what i'm working with..
Old Sep 5, 2011 | 08:50 AM
  #183
92 TOY's Avatar
ouch. 1 step at a time.
Old Sep 5, 2011 | 09:07 AM
  #184
RAWRMON's Avatar
oh yeah.. your pictures are gold to me right now.. i'll post pics of post work.. i gotta get engine cleaner and give the bay a good clean.. the truck sat in our yard for about 6 months with no head.. it was cracked.. got a machined head from some guy that couldn't get the intake off of it.. and it was the reverse bolt that was holding him up.. this engine has alot of guts and once its started it likes to run.. just sick of it running like a v8 and not a 4 cyl.....
Old Sep 6, 2011 | 03:59 AM
  #185
92 TOY's Avatar
if you have a build thread, link it here and we'll all be happy to chime in. most everything I've done, I've felt like I was definitely unprepared and in way over my head. but 1 step at a time and with time at my leisure as I had back-up transportation available....I was able to get this. of course, I had plenty of help right here and spent way more time reading and researching than actual wrenching.
Old Sep 21, 2011 | 07:09 PM
  #186
Lumpy's Avatar
That looks a lil messy...I think the pic's 92 gave ya will work well. He's good like that.
Old Sep 22, 2011 | 04:51 AM
  #187
xxxtreme22r's Avatar
If you think that's messy, you should see my engine bay. LMAO. Right Jerry? haha.
Old Sep 22, 2011 | 04:55 PM
  #188
92 TOY's Avatar
"dirt holding area" is more like it
Old Nov 8, 2011 | 07:24 PM
  #189
MrArmyAnt's Avatar
Thanks for posting this thread on mine. Very helpful. Especially stumbling on 4Crawler's idea to lift the motor for the oil pan. After tons of searching nothing I found was this useful.
Old Nov 9, 2011 | 01:10 AM
  #190
92 TOY's Avatar
thanks man. good luck.
Old Nov 12, 2011 | 07:15 PM
  #191
maistroyoda's Avatar
Very good work. I'll be using this thread when I do mine soon.
Old Nov 13, 2011 | 02:45 AM
  #192
92 TOY's Avatar
very welcome.
**cough**should be a STICKY **cough**
Old Jan 26, 2012 | 06:35 AM
  #193
MisterDolo's Avatar
Thanks a bunch.
Thanks for this write up! This along with the FSM and I think I'll have no issues.
Lastnight I went to check my oil and other things ...... cause I was bubbling back into the coolant overflow tank and overheating (feared the worst and it was true) BLOWN HEAD GASKET! Yellow Sludge Of Death! Its either that or my guides for the T chain are gone and the chain rubbed into the wpump housing like yours. It overheated so Im still going to do the head gasket regardless.
So I'll be tackling this job very shortly.
Couple quick questions ...
1. Did u replace ur oil pump and water pump? Im assuming you did cause they look spiffy on the new TC and was it necessary or did you do it cause it was just a great time to do so? I mean its understandable they really arent that expensive. Need a little advise on that one.
2. Also did u replace your timing chain and sprockets along with the guides?
I'm getting a parts list together as we speak so I can order everything and get started.
On my list of parts to order so far.
1. Timing cover (figured its a good time to do so)
2. Full engine gasket set (DNJ FGS9000)
3. Head Bolts (Afraid to reuse and snap one off in the block EEEEK)
4. Full Timing set (chain, both sprockets, tensioner, drivers side heavy duty guide, and the left to match) But I might just get the guides and chain if the sprockets look decent. However I dont want to have to be taking it back apart any time soon so that's up in the air right now.
I'll be replacing my belts as well.
Thats it so far. I was just wondering if there was anything else you had to get PARTS wise, besides the crank bolt and allen bolt.
Thanks for your time.
D-
P.S. sorry for the novel I just typed out lol
Old Jan 26, 2012 | 05:02 PM
  #194
92 TOY's Avatar
no that's fine.
I believe i may have a parts list somewhere in this thread but not sure.
timing chain (i believe he calls it the FRONT END kit @ engnbldr.com) came with metal guides and new tesnioner and sprockets.
yes on the crankshaft bolt (TOYOTA), yes on the allen bolt (LC Engineering)
the oil and water pump were included with the kit.
good luck.....ask lots of questions....take lots of pics, label lots of bags.
drain that oil now though....
Old Mar 22, 2012 | 05:22 PM
  #195
92 TOY's Avatar
well....update. nothing exciting.
still have and likely will always have, an oil leak from the back of the oil pan due to a bad application of FIPG combined with smearing it when putting the pan on.
so, anyways, some oil leakage is noted and expected by me. I am under the hood about every week to check the oil level. leaks 3 drops....consistently 3 drops....while parked. not entirely certain whether or not it does it while running, but who cares.
today Joe popped the hood to check the oil and I said that it was starting to look wet where the valve cover meets the head and can see some oil on the back of the transmission. I had said we probably would need to change the gasket at some point soon......and he said maybe we just need a re-torque. Joe was right......3 of 4 acorn nuts were able to be tightened by hand. torqued them to 52in/lb and that's it.
not very exciting. but i guess after almost 2 years and several hundred heating and cooling cycles, those little rubber grommets physically change.
bottom line.....check the acorn nuts.
Old Mar 22, 2012 | 08:03 PM
  #196
whelan709's Avatar
Amazing write-up, read the whole thing! thanks for taking the time! Love the amount of pictures!! I will be taking all your tips and tricks into account and going back over it when it come time for me to give it a go.
Old Mar 23, 2012 | 01:39 AM
  #197
92 TOY's Avatar
thanks man.
sometimes I stand in the garage and can't believe we actually gutted and rebuilt these 2 trucks (mine and my son's). just a matter of patience, perseverance, research, time and money........and a willingness to walk away and give it a rest every now and then.
Old Mar 23, 2012 | 08:06 PM
  #198
whelan709's Avatar
I had trouble with knowing when to walk away and give it a rest. but after a 1/2" socket wrench to a fender and $150 later, I figured it out!
And i'm jealous of your trucks lack of rust. Mine is so bad, the front diff cover bushing bolt was rusted into the bushing and I had to cut it out and drill out what was left of the bolt! walked away a few times there!
Old Mar 24, 2012 | 01:06 AM
  #199
Turd Furgeson's Avatar
I'm in the middle of doing a similar job right now,but with a 22rte turbo motor. Blew the head gasket,although I think it was seeping when I bought the truck. Putting a non-turbo engnbldr street/rv head,engnbldr 270 cam,engnbldr 4-piece front end kit,arp studs,ct26 supra turbo on.Got it torn down right now,cleaning parts and getting ready to put it all back together. My first go-round at this kind of thing too.
Old Mar 24, 2012 | 08:31 AM
  #200
whelan709's Avatar
Got a thread or anything on that? Love to see the work you got done to it.
