ball joint spacers need HELP!!!!!
Old Jan 10, 2008 | 07:01 PM
4runnerguy's Avatar
ok has eny one made a thread on how to put in ball joints spacers i have searched and i havent found anythin or if some one god some dimonstration pics that would be awsome
Old Jan 10, 2008 | 07:07 PM
4runnerguy's Avatar
help bump
Old Jan 10, 2008 | 07:11 PM
89934runr's Avatar
BJ spacers
There are the SDORI instructions on their site, as well as on 4Crawler's site.
Here's a few pics that I made of mine- they aren't in instruction / writeup format YET, but it will happen.
http://s215.photobucket.com/albums/c...cer%20install/
To make it easy- get the following:
1. 22mm / 7/8" wrench
2. 3" air grinder- the wheels fit under the UCA real easy; it only took a few cuts to make the right amount of room.
3. a few 2X4s to hold the UCAs up- it makes a HUGE difference.
4. New balljoints- for 35-50 ea, it just makes sense to replace them.
5.Something to cover everything in there- the grinding dust will be everywhere.
6. a 4.5" grinder, or something to round off the edges of the cuts.
More as I remember.
Old Jan 10, 2008 | 07:13 PM
89934runr's Avatar
Other than just shoving my pictures at ya, is there anything I can answer or help with?
Old Jan 10, 2008 | 07:21 PM
4runnerguy's Avatar
no thats good thanks
Old Jan 10, 2008 | 07:24 PM
Jay351's Avatar
Its easier then you think The hardest part for us was getting the spindle back into the upper control arm, we didnt have anything to wedge in there unfortunatly. Make sure before you put them in, you can align it yourself or get it aligned soon. Make sure your tie rod adjuster sleeves are not seized
Old Jan 10, 2008 | 08:27 PM
bry-an's Avatar
knock out the studs from the ball joint before you serparate it from the UCa or you'll hate your life
Old Jan 10, 2008 | 10:04 PM
Bear80's Avatar
Those are some pretty good pictures 89934runr. It looks like you took the t-bars out and if you had spent 5 minutes more you could have just pulled the three bolts holding the upper arm on. This makes cutting and fitting much easier. I took the time to put in new poly bushing in the arms while I was at it. Oh and a cutting disk on a 4 or 4 1/2" angle grinder works prefect.
Old Jan 10, 2008 | 10:11 PM
Matt16's Avatar
Bry-an...Which stud needs to be knocked out before removing the ball joint from the UCA?
Old Jan 11, 2008 | 12:25 AM
ovrrdrive's Avatar
If you're reusing the factory ball joint you have to knock out the 4 studs in the ball joint so you can use the longer bolts they give you with the ball joint. It's easiest to knock them out whilt the ball joint still has the weight of the truck on it, but I just took mine in the garage and put them on the vise and knocked them out.
Old Jan 11, 2008 | 11:23 AM
Jay351's Avatar
Yes, with the balljoint being in place with the weight of the UCA the studs were VERY easy to knock out. But ahead of time, I hit mine with the pb blaster after I removed all the crap off the nuts with a wire brush.
Old Apr 1, 2008 | 10:13 AM
fatmatt473's Avatar
4crawler.com has pics instructions along withs pics.
Old Apr 1, 2008 | 10:41 AM
Beaniam's Avatar
the studs were so siezed into my BJ that I couldn't have imagined trying to get them out without the weight of the truck holding it in place. It took mashing on them with a 5lb hammer to get them out. Had to hit them so hard they started to round over and had trouble fitting them through the holes.
Old Apr 30, 2008 | 01:56 PM
toyotanick's Avatar
isit possible to do this without taking it out of the truck? it definatelly seams like it. o and i have a plasma cutter...
Old Apr 30, 2008 | 01:59 PM
4Crawler's Avatar
Yes, theat is the preferred way:
- http://www.4crawler.com/4x4/ForSale/...owTo.shtml#4WD
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
