Back to the Future
Old Mar 12, 2013 | 01:15 AM
  #121
BK2TFUTURE's Avatar
So what you're saying is just use cheap oil for the "break in" period of 500 miles.
10w30?
Old Mar 12, 2013 | 10:18 AM
  #122
Co_94_PU's Avatar
Let me illustrate i guess.
3.50 a qt, versus, 9.80 a qt
Now assume the break in period is 10 hours(note hours not miles), which do you choose. I choose the cheaper stuff and change it sooner and more often, then dump "the good stuff" in at 10hours. For example after 2 hours(100-150miles) 5 hours (~250-300miles), maybe another at 7-8 hours, and then you can consider "the good stuff".
It's important to change the filter(obvious?) and you don't want to skimp on these, even if it's only in there for the first hour or hundred miles, you want one you can trust isn't going to break/tear and recirculate metal or clog such that the pressure release opens.
There are plenty of oil geeks out there I'm just not one of em. I'd run elephant urine if it got the job done and you needed a lab full of white coat people to tell I wasn't running something else.
Old Mar 13, 2013 | 01:29 AM
  #123
BK2TFUTURE's Avatar
Almost there. Hopefully Monday she'll be back in!
Now, it's not said in the FSM. What are the torque specs for the Air intake chamber and the Cold Start Injector Union Bolt?
Old Mar 13, 2013 | 01:41 AM
  #124
Co_94_PU's Avatar
EG1-80, in the 93 FSM
Air intake chamber x Intake manifold = 14lb
Old Mar 18, 2013 | 11:44 PM
  #125
BK2TFUTURE's Avatar
O.k everyone, everything is on. Everything is torqued. Now we just have to put it in its home. Unfortunately we have to wait til next Monday but we will have her in.
Old Mar 19, 2013 | 12:13 AM
  #126
Co_94_PU's Avatar
Who could ask for anything more!
Old Mar 19, 2013 | 12:48 AM
  #127
BK2TFUTURE's Avatar
I'd really like to do it tomorrow but I have to work with my friends schedule and not mine.
In the mean time I can start ordering misc stuff:
Our bolt pattern is 6x5.5, right? Found the rims, 15x8.
ORDERED!
Old Mar 19, 2013 | 04:31 PM
  #128
Philbert's Avatar
Originally Posted by BK2TFUTURE
I'm not seeing much of a difference (you are the expert though)
I see the stuff in the background is different, license plate, amber covers .... seats??? tires
Mirrors appear to be positioned at different points on the doors.
Also, #2 has the triangle vent windows and #1 does not.....
Old Mar 19, 2013 | 06:56 PM
  #129
Co_94_PU's Avatar
Fixed antenna, power or no ant.
Wide toyota window badge, skinny badge.
Black key cylinder, Chrome cylinder.
Sr5 seat, non-sr5 seat(headrest atleast)
BTTF1,BTTF2
That was fun how did I miss that "game" the first time thru
Old Mar 19, 2013 | 08:10 PM
  #130
BK2TFUTURE's Avatar
Light bar. CHECK!
Old Mar 20, 2013 | 04:37 PM
  #131
JohnnyCanuck's Avatar
I like that, matches your bumpers too.
Old Mar 20, 2013 | 05:57 PM
  #132
BK2TFUTURE's Avatar
Heck yeah they do!
Old Mar 26, 2013 | 12:11 AM
  #133
BK2TFUTURE's Avatar
Long day
before
After
Jennifer is alive!!!!! She runs!
Tomorrow begins a new day. I have a lot of inspecting to do.
Right now my buddy is concerned about the oil gauge. It's not moving. He says after a minute or so the oil gauge needle should go up.
Right now the rebuild is only a few minutes old so is there anything we need to check? I did some searching and found Chef's thread about the sending unit. I tightened the ˟˟˟˟ out of that but I will check again. Brand new sender gauge as well as other brand new goodies.
˟˟˟C YEAH!
Old Mar 26, 2013 | 12:55 AM
  #134
Co_94_PU's Avatar
Oil pressure guage:
Back on page five I can see paint in the bolt holes. But the Sender is already mounted. did you chase that hole or cover it when it was painted, it needs the ground thru the engine. Not going to brave the snow for you to find my spare but i think you can ground the case to check, if not the case then the base for sure.
Old Mar 26, 2013 | 01:22 AM
  #135
BK2TFUTURE's Avatar
The machine shop painted it actually. This is exactly what it looked like when I got it back.
I realized they put this plug where the unit goes but I cannot recall the hole being plugged or covered in paint. I doubt it being plugged though.
Old Mar 26, 2013 | 03:05 PM
  #136
Philbert's Avatar
Nice Supra! What's the story there?...
Old Mar 26, 2013 | 05:46 PM
  #137
BK2TFUTURE's Avatar
I asked my buddy the same thing and it's Stock.
BOOOOOOOOOOOOOOO
Old Mar 28, 2013 | 06:35 PM
  #138
BK2TFUTURE's Avatar
I once had a dog, and his name was BINGO!
The reason why I was only firing on 3 cylinders (#4). Should of looked at this before we put the motor back in!
Thanks to this thread....
http://forum.ih8mud.com/79-95-toyota...lem-i-had.html
Old Mar 29, 2013 | 10:13 AM
  #139
Philbert's Avatar
What harness/plug is THAT?? looks terrible, and terribly fixed before
Old Mar 29, 2013 | 11:51 AM
  #140
BK2TFUTURE's Avatar
Sir, you are looking at the original harness after 26 years.
Wrapped in there are factory splices going to the injectors. Some splices from the injectors are not too far from the bend. The blues. The Yellows. The whites.
This just so happen to crap out on me one day.
In the future, if you have power problems and gone through all the steps. Grab yourself an ohm meter and test the wires.
