Back to the Future
Old Oct 24, 2013 | 06:39 PM
  #361
Teuf's Avatar
Did you clean the dashpot?
Old Oct 24, 2013 | 07:09 PM
  #362
BK2TFUTURE's Avatar
I cleaned it.
I ran a couple of tests. Like what philbert said. I unscrewed it completely and did not have any issues. I drove down the street giving the truck light revs to try to get it stick.
It seems the more screw I have on the dashpot the more likely it gets stuck. So whats the reason for the dashpot? To reduce the drop in rpms?
Do I just drive with the screw no touching the dashpot????
Old Oct 25, 2013 | 04:37 AM
  #363
SqWADoosh's Avatar
Originally Posted by BK2TFUTURE
I cleaned it.
I'm willing to bet your VTV is clogged. Have you cleaned that out with some IPA and then compressed air?
Old Oct 25, 2013 | 06:32 AM
  #364
Philbert's Avatar
The dashpot is there to prevent backfires when you let off the gas. If it weren't there, and you were on the throttle and then quickly let off the gas, the throttle plate would snap closed quickly - this could cause some backfiring. The DP acts as a buffer to slow down the throttle closing, if just breifly, to avoid backfiring.
It's OK to have the DP screw not touching - same as not having a DP altogether since it's not doing anything at that point. I just thought by eliminating it from the equation you could see if it was indeed the stuck DP that was causing your idle issues, versus aybe the TPS, like Swadoosh was suggesting.
Old Oct 25, 2013 | 07:29 AM
  #365
SqWADoosh's Avatar
Yeah I already recommended he do this in the last page of the thread. I'm not sure if he did it though.
Old Oct 25, 2013 | 09:33 AM
  #366
SqWADoosh's Avatar
Another thread just reminded me of something I can't believe I forgot to mention. Air in your coolant system can cause a high idle as well. Make sure to burp your radiator thoroughly with the heat on high.
Old Oct 25, 2013 | 10:06 AM
  #367
BK2TFUTURE's Avatar
I shot this with some brake cleaner. Thats it. I'll have to go get some compressed air to re do the process.
Last night I was driving the truck around the block with the screw completely up and while I was coasting I was lightly tapping on the gas (in neutral) to get the idle to stick. It did not. However I will be doing it again since today is a new day.
For giggles I went to the dealership. That dashopt (diaphragm) is 130 bucks. I laughed. It's also discontinued. I laughed again.
Old Oct 25, 2013 | 11:45 AM
  #368
SqWADoosh's Avatar
Burp her before you go spending any money.
Old Oct 25, 2013 | 12:33 PM
  #369
BK2TFUTURE's Avatar
She's been burped since we put her back together. I will do it again.
Since I cleaned the VTV I'm getting the same thing. This time I've been loosening the screw less and less. Right now I have a couple of turns left before there is no contact.
During this I've been getting less stickage.
Old Oct 25, 2013 | 12:37 PM
  #370
BK2TFUTURE's Avatar
It hangs at a thousand RPM's however if I give the gas a little tap it will bring the idle to the 800 range.
Old Oct 26, 2013 | 07:50 AM
  #371
SqWADoosh's Avatar
Sounds like you have found your problem then. I had to adjust my screw to achieve a good 800 idle as well.
Old Oct 27, 2013 | 12:27 AM
  #372
BK2TFUTURE's Avatar
I'm not sure if I'm liking this.
Letting off the gas at times I get fed back from the motor. This is because the rpms are dropping too fast when I shift.
I guess it is what it is for now ... until I find a replacement.
Old Oct 27, 2013 | 08:17 AM
  #373
Philbert's Avatar
I kind if like it on mine but to each his own.
Maybe remove the dashpot and give it a thorough cleaning?
Old Oct 28, 2013 | 04:31 PM
  #374
BK2TFUTURE's Avatar
Ugggh, again!?
It seemed functional when I had it off and working that spring but I dunno. Instead of brake cleaner, what do you recommend?
Maybe next weekend I will try soaking the dashpot. Tomorrow I start my new job, so I will be occupied with that.
Old Oct 28, 2013 | 06:10 PM
  #375
Philbert's Avatar
Nothing in particular.
Soak in solvent, then use lithium grease to really live it up. Also, like Sqwadoosh said, make sure the filter on it is clean.
Old Nov 10, 2013 | 11:49 AM
  #376
BK2TFUTURE's Avatar
So yesterday I changed the oil for the first time. I've also checked the head bolts. 2 had to be tightened a little. I also loosened up the throttle cable a little and adjusted the stop screw. I was just guessing and where I left it has been good. No issues with the throttle. (knock on wood).
HOWEVER TODAY!
When I was checking the tightness of the valve cover I see some red liquid between the corner of the oil pan and the timing cover. ˟˟˟˟, really? 2 bolts that hold the timing cover and block together were loose. When I tightened them, coolant started dripping on the side. Really?
Screw it. I go underneath and check the nuts on the oil pan. Just about every nut I had to tighten!!
1200 miles and I'm having this????
What are your thoughts?
Old Nov 10, 2013 | 03:53 PM
  #377
Philbert's Avatar
When you put those bolts on for the first time did you dab the threaded ends in silicone so they'd "cement" in more?
Old Nov 10, 2013 | 10:54 PM
  #378
BK2TFUTURE's Avatar
Nope
Old Nov 11, 2013 | 07:40 AM
  #379
Philbert's Avatar
Sorry man - yeah, it's usually in the fsm when you're doing the oil pan and timing cover - you dab some FIPG on the ends of each bolt before you put it on. Helps keep the bolts in, and also helps avoid smaller leaks here and there.
Old Nov 11, 2013 | 10:22 AM
  #380
Redeth005's Avatar
Dang dude. Thanks a lot for the tip. I mean sucks that that happened but I leanred something off your leak situation lol. Ill make sure to do the same thing if I ever need to do a similar job.
