anyone running NWOR idler brace?
i can only get one trail day out of my current idlers. i run the autozone one, so its a free replacement, but the guys at the store are starting to grow suspicious i think. i do plan on getting 4crawlers bronze bushings, but i think i may need more help than that. the only two idler braces i can find are the total chaos and the nwor. the total chaos is out of the question, its over $400 with tax and shipping. i don't know how much the nwor is as they are closed till next year. anyone running this one, or any brace similar and keeping the idler alive for a little longer? the one on the truck is rubbing the frame when i turn so i assume its bent, and i'm hoping bushings and a brace will prevent this. any input welcome, except for sas. i'd love to but don't have the funds for that project.
The total chaos idler isnt a brace, it replaces the whole stock idler and if you are beating on your truck hard enough to take out a idler every trip, it would be well worth the money and piece of mind.
While my truck is 2wd, I used to have a downey brace (thats very similar to the NWOR one) on my stock idler and it helped but I still got a little play from the bushings and bent the arm and brace after a few desert trips.
And while I dont really care for his kits, blazeland makes a idler brace too. http://blazeland.us/idler-arm-kit
If your going through an idler arm per wheelin trip might be time to reduce some front lift. What size ball joint spacer are you running?
What kinda wheelin do you do?
I used to bend them but not that often.
If you SAS you'll never bend another one on your rig
it's not THAT much money if you think of the cost of your time to RR it every time you go out, plus the headache of trying to get your exchange. Definitely cheaper than the damage that could occur if your idler outright failed. I do recall seeing someone make their own BEEFY idler that looked pretty legit and as stout as the TC unit (want to say it was AxleIke when he still had IFS, but could be wrong)
like muddpigg asked - what is the height up front? center axle to bottom of fender
I'm running a Nwor idler brace but I'm pretty sure it only works with the stock arm. I made bronze bushings for my stock arm and haven't bent or had to replace anything yet on it after 3 years and I wheel wheel it on rocks
i have 1.5" bj spacers, haven't touched the torsion bars. not sure of the distance between the hub and fender, haven't measured. i would love to put a solid axle under it, but what little research i've done it looks expensive and not sure i have the fabrication skills to pull that off.
I wrote a build thread on the Blazeland Idler Arm Brace, it covers conception to production. Here is the link.
https://www.yotatech.com/forums/f37/...-brace-242596/
the1998sr5
15
Jul 14, 2020 08:35 PM
