anybody rebuild a CT-20?
Old Nov 16, 2010 | 01:32 PM
GreenFlames's Avatar
hello,
my stock CT-20 turbo charger has stopped building any real boost and is starting to burn through oil. so i have decided it needs to be rebuilt, has anybody done this and does anyone know where to get a rebuild kit. Toyota doesnt sell them anymore. P.S this will be the second time the turbo was rebuilt is it even worth rebuilding again?
Old Nov 16, 2010 | 01:35 PM
dropzone's Avatar
Fossilized
you might try here:
http://www.22rte-trucks.com/simplemachinesforum/
Old Nov 16, 2010 | 07:59 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
no, do not do it...
Get a CT26 off a Supra 7MGTE instead... Writeup is on RTE forums...
(can someone confirm they can see this post? I feel like I'm writing in inviable ink here...)
Old Nov 16, 2010 | 08:24 PM
please read and add link to favorites. (I keep losing the dang thing)
http://www.turbochargerengineering.c...Cat=40#reviews
"As time rolled by, Turbo Engineering Center (TEC). Of Magalia, California found that the life expectancy of the CT-20 was in the neighborhood of 60,000 miles. When it comes time to replace or repair these units, Toyota only offers a replacement turbo for $1850-no service or repairs. TEC traced the CT-20's short life span to the routing of the oil supply line. The line ran directly under the turbine housing and was joined to it. This allowed a great deal of heat transfer and TEC believes oil was ultimately restricted which led to turbo failure. Another shortcoming of the Toyota turbo was the backpressure it produced. TEC tested a CT-20 and found at 9 psi there was 22 psi of backpressure and high exhaust gas temperatures. The conditions were ripe for failure."
Old Nov 16, 2010 | 08:28 PM
DeathSycthe02's Avatar
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
OR
Old Nov 17, 2010 | 03:25 AM
LC engineering sells an adapter for a T3 turbocharger and if I am not mistaken doesn't Volvo use the T3 turbo on a few of the older cars they made? Would a T3 be a good replacement turbo if I could find one cheap?
Old Nov 17, 2010 | 05:26 AM
Greg_Canada's Avatar
There are many, many types of T3 turbo's....
BTW don't rebulid it yourself if you do.. get it professionaly done as it needs new bearings and to be highspeed balanced for it to last...
Old Nov 18, 2010 | 11:23 AM
alrighty, how about these 2 items, http://cgi.ebay.com/T3-T4-TURBO-INTE...item5d2c33dda5, plus this http://www.toyotacatalog.net/M1WebGe...3-912AE038FEC8
Dale Johnston
11
Oct 31, 2015 10:22 PM
the_supernerd
Oct 1, 2015 09:20 PM
ktm192k
Oct 1, 2015 08:47 AM
tylermx71
Sep 29, 2015 08:49 PM
voiddweller
Sep 28, 2015 11:21 PM
