another rear window help topic
Old Dec 30, 2009 | 06:38 AM
cholbach's Avatar
Done a lot of reading on these forums this past week. My problem seems to be opposite of everyone else's. Rear window goes up, but will not go down. Was working without issues previously. Will go down with direct power supplied to the motor. Blue-Black wire has good voltage when window switch is up. Blue Yellow wire has no power when switch is down. Fuse seems good and breaker is not tripped. Where should I go from here. It is my assumption that all the safety switches prevent the window from going up. Am I wrong, is there a switch that prevents the rear window from going down? Neith switch works to put rear window down, both work to put it up. It is an 86 Runner. Thanks for all and any help.
Old Dec 30, 2009 | 06:46 AM
waskillywabbit's Avatar
Rear wiper switch can keep window from going down if it thinks the rear wiper has moved and is on the glass.
Old Dec 30, 2009 | 06:57 AM
cholbach's Avatar
Thanks Waskly will go try it now
Old Dec 30, 2009 | 07:05 AM
cholbach's Avatar
Don't think it is the rear window switch. Had the harness unhooked from the top and it still only goes up.
Old Dec 30, 2009 | 08:12 AM
Junkers88's Avatar
Does it go up and down using the key in the tailgate?
Old Dec 30, 2009 | 09:00 AM
cholbach's Avatar
Junkers, no. window will not go down using either switch. Both switches will make it go up, but neither get it to go down. What am I missing?
Old Dec 30, 2009 | 09:06 AM
Junkers88's Avatar
Damn that is odd. I had a similar problem in that the window would stop about .5" from being fully closed and then not go back down. The keyed switch would work though. I was thinking that you might want to pull the switch out of the console and clean it. Mine was full of old coffee and such and wasn't making good contact inside. I blew mine out with a spray can of WD-40.
That's just strange that neither of your switches work to bring the window down. You said you disconnected the harness going to the top and it still didn't work so that rules out the wiper switch. The window does go down with direct power to the motor.....
How are the connections at the swithes?
Have you traced the wires from the motor to the switches or run a continuity test on them?
edit. I just went back and reread your first post (I should have paid more attention to it the first time) and was wondering if you were doing anything out of the ordinary when the window stopped working.
Old Dec 30, 2009 | 09:09 AM
cholbach's Avatar
In the process of following wires. Pulled switch on console this am and hit hit with a good dose of electronics cleaner-still nothing. Did continuity from down power wire from harness to motor and continuity was good...Is it too early to start drinking???
Old Dec 30, 2009 | 09:14 AM
Junkers88's Avatar
It's never too early to start drinking.
So continuity is good.... WTF? I actually can think of nothing else except being sure that all the contacts are clean and free of corrosion. I wonder if there is a little breaker or something on the motor or maybe an inline fuse? No forget that, if there was a busted fuse your continuity check would have come back negative.
Let me do some looking and see what I can find.
Old Dec 30, 2009 | 09:16 AM
cholbach's Avatar
Thanks Junkers. As soon as my hands thaw I will go back out and continue tracing the power wire.
Old Dec 30, 2009 | 09:40 AM
cholbach's Avatar
more info. did continuity test on blue-yellow wire from relay back to motor and it checked out fine. Could this mean that it is a relay?
Old Dec 30, 2009 | 09:50 AM
Junkers88's Avatar
It might. I don't know for sure if there is a relay in there or not but I would assume there is. Do you have a schematic of the wiring? If not I'll try and find one online.
Old Dec 30, 2009 | 12:36 PM
cholbach's Avatar
Junkers I do hace the schematic. Got pissed and hit the relays with a screwdriver. Window now works! Problem now is that the console down switch only works if the window is not all the way up? Didn't you have a similar problem like that? I did take the switch apart and cleaned the crap out of it. Thanks for all your input on this.
Old Dec 30, 2009 | 01:30 PM
Junkers88's Avatar
*laugh* Well if all else fails just beat the mess out of it!!!
I did have that problem and it was a dirty switch and dirty contacts where the switch plugs into the wiring harness. When I say that switch was dirty I mean it was DIRTY. I probably used 1/4 of a can of WD-40 spraying into it until the liquid stopped coming out brown.
Jun 1, 2021 01:51 PM
dumpster84
Apr 30, 2016 06:03 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
