ac compressor relay...
My 1994 V6 pickup i cant find that round relay for the ac compressor. The other day i noticed that my ac compressor clutch was not coming on when i hit the ac switch the light would come on but no power to the ac clutch so i go direct 12volts to the compressor and it turns on! So i decided to hook up a toggle switch with a inline fuse to engage the clutch direct to 12volts to get it to work so i hope you guys can help me out to find that relay!
Did you also check if the pressure switch is working ??
So with all the safeties bypassed does your system blow cold air??
A copy of the EWD for your truck will help you trouble shoot things
As the compressor clutch is controlled by the AC amplifier after the assorted other conditions are met
That relay is only present on 4wd automatics (which is what 808- says he has). An extra temperature sensor in the water bypass cuts off the A/C when the ECT is too high.
Before I tore my dash apart looking for the relay on a fluke, I'd disconnect the temp sensor to see if that clears up the problem.
I looked behind the glovebox and found the relay for the blower motor i was not able to find the other relay i was talking about. Hope you get yours fixed!!!
Thats good to know. Thank you. I'm wondering if a rat or a mouse has bitten one if the wires? I have it hooked up to a toggle switch so I good with that but if I can fix it like how it was I'm down for that also
That my be the worst resolution you could pick. The compressor isn't designed to run continuously. The Thermal Expansion valve allows refrigerant into the Cooling unit (Evaporator) "as needed" based on temperature. So the compressor cycles on and off based on the pressure behind the expansion valve.
Here's the basic circuit: http://web.archive.org/web/201102052.../2aircondi.pdf
Probably easiest is to make sure the "amplifier" is getting power when the switch is on. Then I'd try checking the pressure switch: http://web.archive.org/web/201102052...19pressure.pdf The pressure switch should be closed with engine-off, and when you force the compressor to run and bring up the pressure it should shut off.
