94 4runner can't lower rear window
Old 03-24-2009, 02:20 PM
fishkiller72's Avatar
I just got a 94 4runner and the rear window doesn't come down. I don't hear the motor running when I hit the switch. The guy I bought it from said the window worked sometimes. I was wondering how to get the panel off the tailgate if the window won't lower. Any ideas?
Old 03-24-2009, 02:35 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
There's quite a few posts 'bout problems with the rear windows, use the search feature at the top of the forum page, under your username in the blue line.
Old 03-24-2009, 03:32 PM
space-junk's Avatar
first, check to make sure that the rear wiper is sitting ALL THE WAY on its cradle... if its not, then the window WONT roll down...
if that dont work, try your key in the keyhole on the tailgate...
if that dont work, call the guy you bought it from and ask for 100 bucks back for selling you a broken truck...
Old 03-24-2009, 04:15 PM
Justinlhc's Avatar
Mine doesn't work sometimes and I just press the "lock" buttom a couple times and it starts working again. Must be a bad connection or something.
Old 03-24-2009, 04:31 PM
Jay351's Avatar
Try using the key in the lock in the tailgate...
Old 03-24-2009, 05:04 PM
should have tried it before posting
right after posting the question I went and tried it again and the window went down, but I had to push it. got the tailgate open and removed the cover. a little rust on the motor. looks like the gear at the motor is stripped. I think I will try to find a motor and regulator assembly.
warrenjcarlson
07-22-2016 11:47 AM
voiddweller
19
05-02-2016 09:10 PM
Corey
06-19-2002 11:06 AM
Quick Reply: 94 4runner can't lower rear window
