92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Mar 12, 2010 | 06:35 AM
  #1201
92 TOY's Avatar
The guide is pretty obvious
The bolt...who the hell knows where that came from?
what is that piece of metal?
and on the bottom left is a black rubbery thing about the size of a pencil eraser.
Old Mar 12, 2010 | 06:36 AM
  #1202
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Put that junk in a box and ship it to Toyota of Japan with a thank-you note! Be like "Thanks for leaving this in my oil pan."
Old Mar 12, 2010 | 06:45 AM
  #1203
yotarob2005's Avatar
Originally Posted by 92 TOY
And now, a better pic of the contents of my oil pan.
washed off and sitting in a jar on my desk to serve as a reminder...
Holy hell man, my guide was split but still intact. The chain must have really been slapping your t-cover.
Old Mar 12, 2010 | 06:56 AM
  #1204
92 TOY's Avatar
what the hell happened to TOYODIY.COM.... it sucks!
I need to find a few things and I want a picture with parts numbers so I could say what the hell they are and have parts numbers.
the LONG ALLEN HEAD BOLT that goes through the intake to just under the thermostat housing
the coolant hose that goes from the driver's side of the timing cover to the block
crush washers for my ?COLD START INJECTOR?
and FIPG
These, along with all my belts are things I want to order from a TOYOTA dealer.
TOYODIY used to have pictures that you could see each part and what part # they were.
Old Mar 12, 2010 | 07:05 AM
  #1205
92 TOY's Avatar
found this
http://www.lceperformance.com/EFI-In...-p/8012418.htm
Old Mar 12, 2010 | 07:13 AM
  #1206
92 TOY's Avatar
OK...added it to my order from LCE
Old Mar 12, 2010 | 09:28 AM
  #1207
Lumpy's Avatar
Not bad...I do like all the junk you had sittin in that pan though. Wow..
Old Mar 12, 2010 | 11:49 AM
  #1208
92 TOY's Avatar
spent a good portion of the day on the computer. And not on YOTATECH...how about that?
Found my local TOYOTA dealer has a parts site and was able to find just about everything that's left to find...3 belts and that hose at the side of the timing cover...I did call there to ask about FIPG...that's impossible to find (ebay 82gram=3oz for $16.25 to my door) versus $15.89 at the dealer....I'm thinking 2 tubes.
I was going to ask about crush washers BUUUUUUUUT....when I asked the lady in PARTS if they had Black FIPG and she asked me "for what year vehicle?"...I knew I shouldn't ask anything more....LOL!
Old Mar 12, 2010 | 11:51 AM
  #1209
92 TOY's Avatar
Also...a newb-type question....I know there are basically 2 types of treatments / coatings for the threads...anti-seize and lock-tite..ish stuff.
what do I use?
Old Mar 12, 2010 | 12:02 PM
  #1210
xxxtreme22r's Avatar
locktite on the crank bolt, anti-sieze on everything else. oil sae 30 should do on head bolts. don't forget to pickup either Vaseline or some sta-lube blue marine bearing grease (that's what I used and what todd reccomended to me) for the oil pump in order to prime it better. Get enough oil/filters to do 2 oil changes one for the first start, then change oil/filter right after running about 20 minutes. I would almost treat this as a full bottom end rebuild as far as priming that pump as the motor has been sitting for quite some time, those bearings are probably kinda dry. Valvoline conventional is what Todd recommended I use on my rebuild since it has a higher zinc content that any other DINO oil. I would also lube up the cam with the bearing grease I had mentioned. I don't wanna look back but did you say you picked up a new cam from ENGNBLDR? if so definitely do the bearing grease and two oil change method. Gonna have to break in that cam.
Old Mar 12, 2010 | 12:08 PM
  #1211
Lumpy's Avatar
Forgot about priming the oil pump, good call... 2x on the anti-seize.
Old Mar 12, 2010 | 12:09 PM
  #1212
92 TOY's Avatar
Thanks for the info.
No , no new cam.
Old Mar 12, 2010 | 12:10 PM
  #1213
92 TOY's Avatar
Don't worry, nobody is going to have a chance to forget anything.....hahahahaha
Old Mar 12, 2010 | 12:14 PM
  #1214
92 TOY's Avatar
this stuff?
http://www.acehardwareoutlet.com/%28...?SKU=998016831
Old Mar 12, 2010 | 12:17 PM
  #1215
92 TOY's Avatar
and this....
http://www.amazon.com/Permatex-81950.../dp/B000HBNVSK
Old Mar 12, 2010 | 12:23 PM
  #1216
Lumpy's Avatar
Sure why not??? Go get some!!! do it, doooo it, DO IT!
Old Mar 12, 2010 | 12:25 PM
  #1217
don't use the engine assembly lube, most are moly based you don't want that. The sta-lube is the right one, however not sure if 3oz will be enough to lube up your stock cam a little and do the oil pump. The only place in stores around here I found the sta-lube grease is A&A. I think it was like $6 for a 14oz container. And then Lock-tite red. Also $6 6ml tube
  #1218
92 TOY's Avatar
hahaha
and this (but RED or BLUE?) http://loctiteproducts.com/products/...ID=10&SubID=48
Old Mar 12, 2010 | 12:27 PM
  #1219
92 TOY's Avatar
as in HOLY moly?
Old Mar 12, 2010 | 12:32 PM
  #1220
Lumpy's Avatar
I was always told that the Permatex lube was good stuff...I donno know... Just cuz I can take it apart does not mean I know how it goes together.
