92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Feb 18, 2010 | 09:50 AM
  #921
Lumpy's Avatar
Hmmmm Loud metallic clicking/clunking/tapping/rapping sound not so good. I would gather to say that yes you had the valve hitting the head which is not really a good thing. Having a cross threaded plug, not too good either.
I'd plan on either pulling the head and replacing at least 1 valve and using a helicoil in plug. Or replacing the head. Might wanna replace the piston depending how bad it's lookin.
But don't touch it until you have some cash and parts, may as well swap cams while your in there. http://engnbldr.com will have all you need.
Old Feb 18, 2010 | 11:05 AM
  #922
86 TOY's Avatar
Originally Posted by olharle
yman;51368719
As for doing the machine shop and letting them rebuild the original head cost per dollar you will come out ahead with the engnbldr head and 261/268 cam.
As for the L.C. Engineering head and cam well I have the Pro Street set up and ended up getting the 268 cam from engnbldr to replace their matching cam and the set is $1049 vs. under $600 (and now he has free shipping) from engnbldr set up with the 268 and if you compare them you will see they are very very close to the same thing with the springs , guides and seals even the cam grinds are close.
all the mods to the head are geared toward better breathing = pulling power/horse power a little better mpg as well , I can run mine(268 cam) up to 52-5300 and it still pulls vs the 261 which IIRC superbleeder says cuts out around 47-4800 rpm hell my truck on 5.29's and 35's runs 90+ miles per hour very easily with a 5 speed
Thanks for the info...sounds like its worth the 600 to get the head and cam from EB. The other post about gettibg it machined threw me off a little.
Old Feb 18, 2010 | 11:34 AM
  #923
92 TOY's Avatar
Originally Posted by 86 TOY
GREAT! Are you getting the Street RV and 268? Or taking yours to the machine shop?
Good luck with the pan...
No
No
No
and Thank-you
gonna shine up what I got because the consensus is that what i've got aint't so bad...yee-haw...sorry.
Old Feb 18, 2010 | 02:08 PM
  #924
Pumpkinyota's Avatar
God your R-motor is built, I'm a little jealous =)
To clarify a little for the less technical, most times on these motors you want better flow on the EXHAUST side only (as olharley states when he mentions better breathing). You don't really want to increase flow on the intake side, unless you have done some radical modifications to the motor, as these engines tend to run a little rich as it is. To drastically oversimplify, more fuel = more horse at higher RPM, better exhaust breathing = better torque at lower RPM. A frequent mistake that beginning builders make is to over-gas or over-cam these motors, or otherwise bolt high fuel volume parts for hi-po applications onto a nominally stock motor. If you want to build it, you have to build it all the way...
If you have some cash and time to throw at the problem, and you want a quick 22-RE, copy olharley's rig damn near exactly, that has got to be one of the better balanced hi-po 22-RE's I have seen...
Old Feb 18, 2010 | 02:10 PM
  #925
Damn skippy!
Old Feb 18, 2010 | 02:21 PM
  #926
Great to hear you're ready to jump back in! Sounds like you've got a great plan on what you'd like to do...very similar to mine. Oil pan is intimidating me a little too and the last time I looked underneath I noticed at least 1 sway bar bolt that has been broken off.
Quick question on the head for those much smarter than me...other than cost what are the performance benefits from taking your existing head to a machine shop? I was also considering the street RV head from EB and was curious if the machine shop could make my stock head BETTER than a new one from EB or LCE? What do I need to tell the guys at the machine shop I'd like done to improve the performance of my head?
Olharley is right, as far as machine shop vs new performance head, new performance head always seems to be cheaper. I can't for the life of me figure out why, as in both cases a machine shop is doing the work, but there you have it.
However, you can do a rough port and polish yourself, if you have some basic shop tools, a steady hand, and patience. Here is a link to step by step instructions from Popular Hot Rodding:
http://www.popularhotrodding.com/tec.../photo_10.html
I have never tried this myself, but from what I have gathered so far here are some important differences from doing this to a V8:
Port and polish the exhaust side only!
Don't remove much material, and be careful of getting too close to the valve seat.
I am casting about for a spare head now, to disassemble and test this on...
Old Feb 18, 2010 | 02:23 PM
  #927
92 TOY's Avatar
OH dear yes!!!
If I could copy what he has done, I'd be VERRRRRRRY HAPPY. But gotta save up those pennies to do that. I've read his write-up, knows his stuff and has been an absolute resource and inspiration for me...whether he knows it or not.
My current life (as is the case with most everyone) is "if I do this, then I can do this" and so on and so forth.....as in, if I get this successfully buttoned up the I can sell the Caddy and get the 88 4runner on the road with the proceeds from that sale...and on and on. My life is like a house of cards...if 1 thing goes wrong........
Old Feb 18, 2010 | 02:27 PM
  #928
OH dear yes!!!
Yeah, I don't have the time or cash either =/
It's got to come eventually right?
Old Feb 18, 2010 | 02:35 PM
  #929
92 TOY's Avatar
pffft on that
Old Feb 18, 2010 | 02:36 PM
  #930
86 TOY's Avatar
No
No
No
and Thank-you
Nothing wrong with savin some money and rollin with whatcha got! Hope you get your computer/camera thing fixed up... pics of the oil pan removal would be great.
Old Feb 18, 2010 | 02:40 PM
  #931
92 TOY's Avatar
ahhhhh yes....the computer
LUMPY fixed me up with that, so I got my desktop back on the road now and I can actually type like normal, so my spelling should be better too.
I haven't tried loading any pics on it yet, not that I have anything interesting because it's toooooooo G-D cold to be laying on that floor....could be worse though...
Old Feb 18, 2010 | 03:47 PM
  #932
Lumpy's Avatar
Ya it could, it may be cold but at least you're covered...
Old Feb 18, 2010 | 03:49 PM
  #933
ayoung101's Avatar
haha 92, i'm not gonna go back and catch up. i've been gone for a few months now, ARE YOU DONE YET?
Old Feb 18, 2010 | 03:51 PM
  #934
Lumpy's Avatar
Come on read up!!! We've all endured this one...he even has new subscribers that have read it alllllllllll
Old Feb 18, 2010 | 03:56 PM
  #935
92 TOY's Avatar
I was wondering where you got to.
nahh......called it quits in the fall when I was trying to get at the oil-pan and ended up breaking bolts getting the swaybar partially off....anyway, then I had no money...no ambition...basically said the hell with it until now. income tax refund deposited and I was just on ENGNBLDR's site.....I'm gonna email him...because if I order off ebay it's like 3 or 4 different shippings but if I order right from him it would be combined, I assume...so I will just have to wait until Saturday to check again.
so, stay tuned, it's gotta get warmer and I will get my butt back out there.
  #936
92 TOY's Avatar
I don't know if that is a good thing or a bad thing....I kinda feel sorry for them.
Old Feb 18, 2010 | 03:59 PM
  #937
xxxtreme22r's Avatar
it was almost 45 degrees today did you get any work done ? haha
Old Feb 18, 2010 | 04:01 PM
  #938
92 TOY's Avatar
hahahaha...
yeah, I heard 46....but I was trapped in training the last 2 days and I work tomorrow...supposed to be 7a-7p, which usually is 630-8p...I'll take the extra $$$ though.
Old Feb 18, 2010 | 04:36 PM
  #939
92 TOY's Avatar
But seriously man....how do ya do it??
How can you NOT be on YOTATECH every day and hours and hours every waking available moment
For some dang reason I'm TOTALLY addicted to this site...ask my family...wife especially.
If I'm not catching up on the antics of the boys on the "BUMPER" thread or BLEEDER and TEUF on the "USLESS" thread..I'm ping-ponging my way around on here...usually getting my balls busted on my own thread or talking non Toyota with LUMPY.
This is like convincing someone it's actually GOOD to smoke. But that's me, my 2 bad habits...YOTATECH and smoking.
What is it I do for a living again???........hahahahahahhaha
Old Feb 18, 2010 | 04:53 PM
  #940
92 TOY's Avatar
doing some shopping on engnbldr's EBAY store:all prices are final price w/ shipping
($157.58)Timing Cover w/ oil and water pumps, new timing set and gaskets
($46.90) Head gasket kit...all necessary gaskets / seals etc
($37.98)New head bolts
TOTAL $242.46
Thing is,if he combines shipping I may save a few bucks...maybe $10...whoopie! But it's $17.60 (timing cover) / $10.00 (headgasket set) / $10.00 (head bolts).
I know I just shipped a 28lb something for under $16, so likely he could combine all that in one.
