92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Nov 22, 2012 | 02:54 AM
  #3761
92 TOY's Avatar
just ordered one for $5.88 off ebay
Old Nov 22, 2012 | 07:05 PM
  #3762
Terrys87's Avatar
Try the new cap and burp the system. Not sure how you burp your system as I have heard there are a couple of different way, but here is how I burp mine with the cap off and let run for about 15 minutes and always works great for me. It is higher then it looks as I am 6 foot tall and the fill neck comes up to about my shoulders.
Old Nov 23, 2012 | 01:55 AM
  #3763
92 TOY's Avatar
nice pic.
I haven't ever had a problem burping it, as my driveway points up a bit towards the garage. hopefully it's the cap. If it's not the cap, I'm at a loss.
Old Nov 28, 2012 | 04:14 AM
  #3764
92 TOY's Avatar
alrighty. got the new cap 2 days ago and put it on today (cuz I've been using Joe's 4runner for work). fits very well. let the truck running in the driveway for about 20 minutes and then took it for about a 20 minute ride.....no problems. so I'm thinking it was likely a bad seal on the cap. probably wore it the hell out because I am neurotic about checking the fluid level and oil and everything....unlike how I used to be.
so.....STANT 10229 is the one to use. so, thanks TF and Terry!!!
Old Dec 14, 2012 | 04:24 AM
  #3765
92 TOY's Avatar
so...yep.
truck still runs fine...mostly.
starting to make me a bit nervous with some little gremlins here and there.
speedometer stopped working altogether about 2 weeks ago. would not work sometimes and worked just fine other times. so now I am going to have to search and fix the darn thing. although I'm not overly concerned about speed anyways, because my trip to work is fairly routine and I just keep up with traffic. in the past, I drove without dashlights for a few years and still was able to accurately tell how fast I was going by how the truck acted. but, yep, something I have to fix.
I'm a bit nervous I may have a headgasket issue, in that I am losing coolant ...somewhere. no visible leaks, but my old body does not want to get under the truck more than I have to. so, for now, I keep it topped off.
oil leak is same as it was from the pan, but unfortunately, I think I can see oil coming from above that area too. hoping that it's just the valve cover or half-moon plug, but dreading that it ay be something more. don't have the finances right now to do any major repairs, so I will try to limp it until the spring and likely pull the motor and do it the right way instead of breaking my arms attempting a partial rebuild in the engine bay like I did.
would love to give this thing a frame-up restoration, since eventually I would love for it to be m little guy's truck (he's 11) and my wife's 4runner mine. still have to pay her's off and then it will be mine and she can get something else.
so things are status-quo.
Old Dec 14, 2012 | 04:44 AM
  #3766
92 TOY's Avatar
still have to check compression to the cylinders to start the rule-out, rule-in process.
should pressurize the cooling system to do the same too.
a few moths back , sometimes when I would start the truck it would run like hell until I hit the gas a few times, almost like it was starving or that maybe (and I hope not) like a plug was fouled. when I pull plugs eventually to check compression , I will also check the plugs and try to get a peek inside to see what the piston tops look like.
for now, I know that Joe's 4runner runs well and is there in case mine just dies.
Old Dec 19, 2012 | 04:25 AM
  #3767
Terrys87's Avatar
I hope it isnt a head gasket issue, especially as careful as you were putting it together. What about your cooling fan, maybe it isnt functioning properly and causing a heating issue,dont think I seen you mention thermotat, but I could of missed it. If you are not finding any leaks, check the exhaust. My 91 was losing it thru the exhaust valve and out the tail pipe.
Next time you tune it up or pull the cover off, retorq the head bolts and see if any are loose. I sure hope you dont have to go thru a head gasket again.
Your speedo is electrical driven. They changed in 91 from mechanical to 92 electrical. If I recall right, it is just a plug that connects to the speedo on the tcase. I have that SR5 guage if you need it. You would just need to adjust the tach and change sending units. It is out of a 94 Runner 3.0 auto.
Having a daily driver down is nerve wracking, I feel for you on that. If by chance you do have to do it again, it does make it so much easier on the bones working on it out of the truck. I can understand having to get under it as age starts to have it say. Losing flexibilty.
Maybe someday you will get to do a frame off resto on your 92. If that day does come up, dont let it worry you. They are easy to to do, just takes alotttt of time, but is rewarding and with what your truck and the length of time you have had it, it would be special.
Old Dec 19, 2012 | 05:50 AM
  #3768
92 TOY's Avatar
probably today...maybe not...I will start flipping through my FSM and research what to do. the speedometer is not so much a worry for me, but a worry when Joe borrows my truck...not cool.
as far as the leaks....yeah, you and me both on the head gasket issue. but as compared to doing the whole shebang like last time, it should be relatively "easy''.
would love to do the whole frame-off resto....likely would be a box-off resto though leaving the cab in place. would love to rhino line the underside of the box to make it last a wee bit longer. I have rust on the box that I've repaired but will only last so long.
would love to eventually make this truck my youngest's truck.
keep holding that gauge pod....teehee
EDIT...I have the dual-stage thermostat. no overheating issues since that one day, but am still losing antifreeze.I have slowly been adding toyota red to the mix so I will be able to dilute my water as well as pick up any smell of antifreeze.
Old Dec 20, 2012 | 01:56 PM
  #3769
92 TOY's Avatar
for the future...on the wife's 4runner
http://www.4runners.org/writeups/sat...atoshi_p2.html
EDIT:
adding a pic for a part #
TPZ $24.25
TPZ $26.45
PLUS $12.41 shipping = $63.11
Old Dec 21, 2012 | 05:46 AM
  #3770
irab88's Avatar
dam- $26.45 for that part plus shipping
that looks like a mod i might have to partake in. and there's this shop for all sorts of expanded metal:
http://www.mcnichols.com/products/ex...standard/#none
also, here's a list of many (151) toyota emblems. copy the p/n to google images to see what it is
http://www.toyotapartszone.com/parts/toyota-emblem.html
Old Dec 21, 2012 | 04:37 PM
  #3771
92 TOY's Avatar
tanx.
gonna have to remember I'm posting this here.
Old Dec 22, 2012 | 03:30 AM
  #3772
92 TOY's Avatar
ugh. the search feature
https://www.yotatech.com/forums/f116...ittent-235134/
Old Dec 22, 2012 | 03:59 AM
  #3773
92 TOY's Avatar
once again, my FSM leaves me no more informed than before I read it. booooooooo
after doing some searching and reading I have come to the preliminary conclusion that the VSS (vehicle speed sensor?) is still working since I have functional odometer and trip odometer but no speedometer (although it worked for a few minutes yesterday).
Old Dec 22, 2012 | 12:07 PM
  #3774
92 TOY's Avatar
well...did some reading and I really don't want to chuck the whole cluster because the speedometer is not functioning. saw some talk about how people just use their GPS...no worries. I had been searching about how to do an aftermarket speedometer...so I got to thinking. so I downloaded a speedometer APP....an it actually worked. these cooky people, what will they think of next?
Old Dec 22, 2012 | 02:31 PM
  #3775
BigBluePile's Avatar
Fix it yet?
Old Dec 22, 2012 | 03:10 PM
  #3776
92 TOY's Avatar
Fix it yet?
well. sorta. I blame Josh.
(the following pic is a joke)
Old Dec 22, 2012 | 05:15 PM
  #3777
You burnt your truck to the ground....?
Juvenile.
Old Dec 22, 2012 | 05:22 PM
  #3778
92 TOY's Avatar
what? you and Josh told me to.
say you're sorry.
say it!
Old Dec 22, 2012 | 05:36 PM
  #3779
Um.....no...?
Old Dec 23, 2012 | 01:21 PM
  #3780
92 TOY's Avatar
dork.
OK..so...here's the android app I'm using. tested it out today when driving Joe's 4runner. pretty cool. https://play.google.com/store/apps/d...ys.speedometer
this will keep me in good shape until A)I get a gauge cluster (hello Terry..just not sure how to swing that one) or B)I get a dedicated GPS or C) I figure out some way to fix this. I find it very hard to believe that the solution is to swap clusters....seems like we fix everything around here but this is not fixable?
