92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Apr 28, 2010 | 06:35 AM
  #2281
Lumpy's Avatar
Yeah!!!! Good real good...
Old Apr 28, 2010 | 06:54 AM
  #2282
92 TOY's Avatar
and a better pic...
and this pic means alot to me.....it's my labeled bags getting stuffed in the garbage
and the NEW AND IMPROVED tool
Old Apr 28, 2010 | 06:56 AM
  #2283
Lumpy's Avatar
Don't fret about the intake side either...it's not as bad as it seems...
Get those 3 nuts nice and snug, I lost one of mine. It just vibrated loose.
Old Apr 28, 2010 | 06:59 AM
  #2284
92 TOY's Avatar
for the most part...disassembly I had considered to be easier than re-assembly....but as far as those 3 nuts on the down pipe and the exhaust manifold attachment...it really went smooth.
and , even though i have not tightened up the down pipe yet, i was able to finger tighten the nuts on the studs from above....which is a helluva lot easier than when i struggled to get them off of there.
Old Apr 28, 2010 | 07:02 AM
  #2285
malteserunner's Avatar
Looks shiny!! Nice work Jerry.
  #2286
92 TOY's Avatar
and.....i haven't searched the FSM yet....and i will, but i'm thinking the same 33 ft/lbs for the down pipe.....and yes there are new gaskets there....weird looking ones too....like compressed tin-foil or something like that.
Old Apr 28, 2010 | 07:04 AM
  #2287
92 TOY's Avatar
thanks...i haven't found any stray tools in my truck yet....but i AM the original owner so i would only have myself to blame for that.
Old Apr 28, 2010 | 07:05 AM
  #2288
92 TOY's Avatar
God, i hate laying on that floor working above my head......at least Pink Floyd is jamming out there.
and away I go..................
Old Apr 28, 2010 | 07:34 AM
  #2289
92 TOY's Avatar
waaaaaaay up there...
and can't forget this holding to the transmission....
and seriously, who the hell put this together upside down?
Old Apr 28, 2010 | 07:41 AM
  #2290
92 TOY's Avatar
let me just take a moment to say that, for 99% of these pictures, i have been using an absolutely beat-up, old, 4.0MP Fuji camera......i hope it never dies.....we have a 10mp camera that does not take pics as nice as this does.
Old Apr 28, 2010 | 08:02 AM
  #2291
Lumpy's Avatar
Fuji Fine pix??? Thats what I got...Hehehehe
All I can say is keep up the good work man your cruising right along.
Old Apr 28, 2010 | 08:13 AM
  #2292
yotarob2005's Avatar
My Kodak finally bit it just the other day.....It was a good camera, can't belive that I dropped it.
Old Apr 28, 2010 | 08:28 AM
  #2293
snobdds's Avatar
There are three bolts that connect the heater bypass tube to the back of the timing cover. The only way you can access them is with the power steering pump and bracket off of the head. Make sure it is sealed up really well and the bolts are tight. When I did my timing chain, the only leak I had was that tube and I had to take everything back off to seal up that leak. In fact I had to take the timing cover back off and use FIPG on the tube to get the leak fixed. It was a huge dissappoitment to say the least. Thought I would warn you before you got too far ahead of your self.
Old Apr 28, 2010 | 08:42 AM
  #2294
shawns88's Avatar
pics...
in my labeled bag there were 3 bolts that held the tube to the back of the timing cover on the exhaust side......tube only had 2 holes????....so i had an extra bolt........i suffered all day yesterday and again today trying to figure out how the hell that could be......so, now i made it extra tough on myself and have the power steering in the way so there was NOOOO chance of seeing there, so i felt around and sure enough i could feel where it should go......don't know what it was for, i have a feeling it's to hold the back of the power steering to the back of the cover but i'm not sure.....snapped a pic of the area but it really does not show anything...
OK....on with the show...
don't know why, but i felt like putting this sticker on...since i do officially have LC Engineering parts on here and the receipts to prove it......so here you are.
and this is how it started........i put PB BLaster on the studs and ran a nut on each of them....then i took each nut and put it on each bolt....to make sure there were no burrs or any issue...there were no issues....except, 1 stud had come out on disassemble and still had the nut attached....i left it like that "leave well enough alone...."
and then THIS....let me tell you, trying to get the 3 studs to line up with the down pipe while putting this on is a PITA and need 5 arms to make it happen.
and then this PITA thing.....very hard to make it line up with the tube it mates up with....VERRRRRY HARD indeed.....was having horrible thoughts at this point about having to remove the head because i thought i had something ass-backwards......but alas, i became creative........i excel in that department....
PINCH IT together with vice-grips....hehehehehe
with a little masking tape to protect everything...
and there ya have it.....everybody is torqued down to 33 ft/lbs like the book says.......finger tight from the center out and round and round for several passes until it was time to get the torque wrench on it..........
looking gooooood....
you got lucky =P all but 1 of my studs backed out. did you do a head gasket?
Old Apr 28, 2010 | 08:47 AM
  #2295
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
I can give you some tips on getting better pictures with your supposedly "better" digital camera. I've noticed that a lot of the point and shoots these days will auto-select ISO level, an seem to enjoy auto-selecting ISO80 or ISO200 when taking pictures of rusty old 'yotas, which results in some real grainy images (or fairly blurry in the case of ISO80). If you still have your camera's manual, flip through it and look at how to turn off the auto-ISO and then set it to at least ISO400, that's usually good enough for nice big and crisp images with a lot of stuff in the foreground.
Old Apr 28, 2010 | 08:50 AM
  #2296
92 TOY's Avatar
the tube only had 2 holes...that was what was confusing me....i feel confident all is well in that area.
Old Apr 28, 2010 | 08:51 AM
  #2297
92 TOY's Avatar
yes.....head gasket / timing chain / timing cover / pan removal...........hey that feels good to write.
Old Apr 28, 2010 | 08:54 AM
  #2298
92 TOY's Avatar
aye, aye MAG...will do.....will read up on tha.
I really was only making the point that my crappy 4.0 takes really good pics. my son bought the 10.0 and i have an HDD video camera with a 5.0....but of all of them this beat up, cracked, markings-missing about 8 year old camera still does the job.
Old Apr 28, 2010 | 08:57 AM
  #2299
shawns88's Avatar
i just replaced mine last week, had to take the head and the intake in one pice because 2 bolts snaped off.
Old Apr 28, 2010 | 08:59 AM
  #2300
92 TOY's Avatar
so...wow...
put the heat shield back on...
and then frigging argued and struggled to get the intake off of the one stud it was hooked to......was binding real hard at the area where the EGR(or PAIR) tube? meets with the REED VALVE? and was making me unable to maneuver around........sometimes a lighter touch is what is needed, so i stopped struggling and just finessed it off of there.
so here's how it sits now......and I put the water neck back on.....what's with all the RED?....OY!...I may rethink some of this coloring....anyway....
