92 4run questions
92 4run questions
Hey man I am stuck My toy will start but once I step on the gas to start off not hard just normal, The engine light comes on? TPS sensor? the truck runs fine for the first 1/2 hr then it will stall or stumble "loop" if you will even while driving. the truck is retarted on gas I mean 30$ @ 98.6/litre gives me about 150km and I'm lucky if I get that I put new Plugs Bosh4, Wires, cap, button, K&N filter checked the rubber intake hose and collector boxes for holes, none. Seems to have even compression, The map sensor checks out any ids guys I am stuck
i've come to find out it is the knock sensor (code 52). when I traced the wire, I found it was cracked and corroded just below the intake, where it comes out of the block (between the connection and block). Any suggestions on how to fix this?
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
