92 22re fuel pump wiring
Old Nov 14, 2016 | 01:18 PM
hcobb32's Avatar
Update is I replaced efi relay and jumping the two terminals still does nothing. I must have bare wire somewhere. Going to check that next. Efi fuse is good. Efi relay is new.
Old Nov 15, 2016 | 08:17 PM
RAD4Runner's Avatar
By "bare wire" you're susoecting a short? But if you had a short, you'd be blowing fuses.
​​​​​Inspected the condition of wires at fuel pump?Find schematic (I wish I could share, but mine's for an 8622RE), and get a multi meter, then start checking for voltage?
Old Nov 16, 2016 | 05:53 AM
scope103's Avatar
Originally Posted by scope103
... You never tested B+ (measure voltage to ground; with key-on you should have 12v), ... The correct test would be to use your multimeter to check for voltage on B+.
Update is I replaced efi relay and jumping the two terminals still does nothing. ...
Have you tested B+? It sounds like you went ahead and replaced one part without a reason to do so.
If you don't have 12v on B+ (and you've replaced the relay w/o testing the old one), check for 12v on the "input" side of the relay, and continuity to B+ on the "output" side. There are lots of possibilities, but 12v isn't getting from the battery to B+, you just have to find where the disconnect is.
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
redneck17
Jul 17, 2015 07:44 PM
