91 Toyota speedometer problem
Old Sep 7, 2015 | 12:19 PM
toyotafreak98's Avatar
My speedometer quit working and I can't find out why. Its a 22re I was driving and it all of a sudden went to 0. So I thought it was the cable,when I got home I unhooked it on both ends and I was surprised to see that if I turn it the other end turns as well so the cable works.
I am stumped any ideals?
(EDIT) I think it is either my speedometer or the drive gear. I took the cable back off at the ends and spun it with a drill (on low). It got up to around 30mph. So I believe the cable is not the problem. I pulled the speedometer gear and to be honest it really didn't look that bad a little worn but not bad.
Old Sep 8, 2015 | 06:34 AM
scope103's Avatar
You're going to have to break this down into steps. You've already done the first two; you've verified the cable isn't broken, and you've verified that spinning the cable will work the speedometer.
So, even though the drive gear looks okay, I think it's time to try it. This shouldn't be too hard; disconnect at the speedo and connect at the transmission. Jack up a rear wheel and turn it by hand. Does the cable turn at the speedometer end?
Old Sep 8, 2015 | 03:08 PM
Got it the gear was bad Thanks
Old Sep 9, 2015 | 06:22 AM
scope103's Avatar
Thanks for the report back.
Pictures? Part numbers? Where you bought the replacement, and how much it cost? Inquiring minds want to know.
Old Sep 9, 2015 | 01:21 PM
I can post a pic and part number tomorrow I had to order it thru the local Toyota dealer.
It was $31 and some change kinda high for a little plastic gear.
Old Sep 9, 2015 | 03:54 PM
Odin's Avatar
Excellent suggestion, I've often wondered why more people don't do that. Makes it easier for those who have the same problem.
Some people just put a picture up and say I got this and don't type the part numbers they used.
Some just put up a link without typing in the part numbers they used.
Both methods have one major flaw in common.
What happens when the picture is moved/deleted or the link is no longer good???
Old Sep 9, 2015 | 03:55 PM
scope103's Avatar
Originally Posted by toyotafreak98
... It was $31 and some change kinda high for a little plastic gear.
Maybe.
But try getting ANY part for your 25-yr old TV / Computer / Sofabed / Discman / Telephone.
Old Sep 10, 2015 | 01:03 PM
Maybe.
LOL true. The Toyota part number is 33482-39135
Old Sep 10, 2015 | 01:22 PM
Terrys87's Avatar
Wish more would post their results, parts and prices. Thanks for the report back.
Old Sep 10, 2015 | 02:57 PM
No problem
Jnkml
Jul 6, 2015 01:20 PM
bigblue82
10
Jul 6, 2015 08:27 AM
hhsanfor
Jun 30, 2015 06:08 PM
ACZR
Jun 23, 2015 07:55 PM
