90' 4Runner chop
#81
One more thing, you might want to reconsider mounting your fuel tank out side the cab. It will make it easier to fill and most importantly, Vent the fumes created when sloshing around, not to mention, putting added weight over the rear axle.......adios chelu'.............
#82
LOL Che'lu! Are you here on Guam? or Stateside? Anyway, thanks for the pointers! The fuel cell mount is capped, no vents or fumes will come in(I made sure of that) but for putting the gas in, I will be mounting a hose to the rear side.
I hope that the metal doesn't distort, but will consider welding a bracket to the exo when it is done(thanks)
Body work will be done soon so that no rust will come of it. This is my first time welding so I tried to make whatever I did "work" for me. I did learn a lot from this experience so if I ever do something again I'm hoping that my welding would be better. I did use some silicone to seal the gap I had. Been using silicone and it works like a charm, soft, flexible easy to repair, durable and it's cheap. Thanks again for your input! Esta.
#84
Got me some new shoes and decided to try them out..... had a great time till the bead popped.... LOL
here are some pics and a vid
http://www.youtube.com/watch?v=cB98wGSSqJc
That's all I have, might get more pics later.
#87
Thanks for the comment mang. Funny thing is I haven't really got the chance to wheel since 2001. My runner has been down since.... So we're kind of in the same boat. The trails have changed much since. And 38s are like the "new" 33s hahaha. Anyways, if you ever come back check me out. I will try and post some pics . Shoots
#90
#93
Found a full width Daimond to match the T100 rear
Wider is Beder...
Wider = Dirty faster......
Came with dirty 30s long inners and an ausie locker
I'll try and get some better pics...had too much fun behind the wheel that taking pictures were not as fun
Wider is Beder...
#95
#96
New Year's run 2011
Testing the strength of the Diamond
http://www.youtube.com/watch?v=esH96A6r6GY
Enjoying the difference a locker makes
http://www.youtube.com/watch?v=E4z3xByxLBk
Next on the list are the rock lights install, exo and bodylift removal
#100
Started working on my 3.4 SWAP this past Sunday!!
I won't be posting a build thread because I think everyone who did already covered all that needs to be covered. I will however let you guys know if I run into trouble or found other ways of doing it and post in the 3.4 swap section.
Things that will be done in the swap are simple:
-motor swap
-after market intake
-Doug thorely headers (exhaust will be going down the passenger side)
Wish me luck
-motor swap
Wish me luck
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
