89 Truck-no torque in gear
Old Jan 28, 2014 | 07:42 AM
89Redyot's Avatar
I have an 89 SR5 V6 auto 4X4, engine runs great and strong in neutral, when it is in gear it has almost no torque or power. I have to turn overdrive off to accelerate and go up hills. Need help trouble shooting. Anyone else had a similar problem?
Old Jan 28, 2014 | 09:51 AM
rattlewagon's Avatar
What have you done as far as trouble shooting goes?
Got coolant? Compression test? How are plugs/wires? How does the oil look in the engine/tranny etc, break stuck on?
Lots of variables here. Help us help you. The more info you can give the better.
Old Jan 28, 2014 | 09:54 AM
89Redyot's Avatar
Just had a tune up, everything on the engine checks out good. The brake is not on. The engine is solid and revs great and has plenty of power until you put it in drive. You can put the pedal to the floor and it creeps along like something is holding it back.
Old Jan 28, 2014 | 10:15 AM
nothingbetter's Avatar
Has your truck given you a milkshake? Check your coolant and tranny oil to see if they look normal. If you don't know what I mean, search "toyota milkshake" with your internet search engine of choice.
I'm not familiar with that engine/tranny but the milkshake is what pops into my head.
Old Jan 28, 2014 | 11:01 AM
89Redyot's Avatar
Coolant and trans fluid are fine, no issues
Old Jan 28, 2014 | 03:40 PM
How long have you had the truck? Does it have the correct fluid in it?
Old Jan 29, 2014 | 04:44 AM
89Redyot's Avatar
I have had the truck about 2 months, all the fluids are correct and clean.
Old Jan 29, 2014 | 06:41 AM
CJM's Avatar
CJM
How many miles, wonder if the cat converter is clogged up.
Old Jan 29, 2014 | 06:52 AM
89Redyot's Avatar
The truck has 152K, the entire exhaust system was recently replaced from the headers the whole way back. It acts like something is wrong with the tranny. Out of gear it has plenty of power. Any other ideas?
Old Jan 29, 2014 | 07:38 AM
blake.nemitz's Avatar
what is your timing set at? try advancing a little. if its too retarded it will rev up in neutral and sound fine but have no power to move fast anywhere.
Old Jan 29, 2014 | 10:21 AM
89Redyot's Avatar
I have not checked that yet. How do I do it?
andrewtexas123
Jul 6, 2016 01:49 AM
rustym
Aug 7, 2015 10:39 AM
91yotapup
Jul 27, 2015 07:19 AM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
