88 3.0 4x4 shocks. and suspension advice needed
Old Nov 4, 2011 | 12:48 PM
idanity's Avatar
i need to replace the front shocks in my 88 4x4.
what are some good (quality and affordability) rated shocks you guys use ?
also.
do i have to replace the horizontal shock in the front ?
it looks like a very easy job, but they are likely to be rusted on, so, any advice in possible things to avoid too ...
and, when i replace the worn out front shocks, will the front end rise, and make the back look saggy... ? ... if so, is there anything i need to do in the back ?
Old Nov 4, 2011 | 01:11 PM
dubbsbetty's Avatar
Replacing the front shocks is very simple. The horizontal shock is called a steering stabilizer, u do not necessarily need to replace it but it wouldn't hurt, its mainly designed for wheel wander, so if you have stock tires you'll be fine. The fronts will have a very slight to no difference in height being new. I just put the Pro Comp ES9000s and so far I like em'.
JF9243176
Oct 8, 2017 04:21 AM
Nathan_F
Aug 19, 2015 04:03 PM
JF9243176
Jun 24, 2015 04:53 AM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
