87 steering box nightmares.
Old Aug 7, 2020 | 06:42 AM
bayoulee's Avatar
Anyone else had problems with steering boxes? In the last 3 years or so, ive been thru 4 Boxes. Original started leaking, put on a used one that lasted no time before it started leaking. Ive put on a new one, that lasted no time, replaced it and now this one is leaking. Anyone else have problems with these?
Old Aug 7, 2020 | 08:19 AM
5 Fists's Avatar
I think you can rebuild the steering box can't you? Maybe it's time to go that route instead of replacement?
Old Aug 7, 2020 | 09:12 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I resealed mine, and other than taking the spiral gear out(which the manual told me not to do) and having the individual ball bearings roll everywhere, it was pretty straight-forward.
Under most cases I've found it better to rebuild the genuine Toyota component whenever possible rather than get a aftermarket one. And a used one will typically have the same issues as the one you're replacing.(or worse)
Old Aug 7, 2020 | 03:40 PM
wallytoo's Avatar
kind of like building a castle upon a sunken castle upon a sunken castle.
Old Aug 7, 2020 | 05:05 PM
superex87's Avatar
Ar you using power steering fluid or automatic transmission fluid?
Old Aug 7, 2020 | 09:33 PM
Co_94_PU's Avatar
*this
While hydraulic fluid is always hydraulic fluid there are known issues with seal and metal issues.
Old Aug 8, 2020 | 06:36 AM
Dr Phat's Avatar
Originally Posted by Co_94_PU
*this
X2 on this.
I just bought a 88 pickup and found the last owner was not using ATF. The oil seemed thicker than power steering fluid but whatever it was I flushed the system out and replaced it with Mobil1 ATF, hopefully it didn’t destroy any of the seals, but time will tell!
Old Aug 10, 2020 | 05:36 AM
bayoulee's Avatar
Ive been using power steering fluid.
Old Aug 10, 2020 | 06:13 AM
Dr Phat's Avatar
Drain the system, put a new box in or new seals, then flush the system with ATF (Dex-II/III I believe is the most correct) I used Mobil1 Synthetic ATF.
Old Dec 9, 2020 | 09:35 AM
RAD4Runner's Avatar
Correct^^^.
edeslaur
Feb 27, 2013 12:24 PM
LRC79
Apr 5, 2011 08:03 AM
EricH87P/U
Jun 2, 2010 11:25 AM
hilux
Jul 24, 2003 06:43 AM
