87 22R A/T wont shift 3 / O/D
87 Toyota pickup 22R 220,000
Got truck from granddad when he passed away. just trying to get it back the way it was when I was a kid.
I have search with some help but no fix.
1st to 2nd shifts good, 3rd and O/D I have to let the gas go then it shifts.
I adjusted the (kick down) cable and its sitting now about half way with alittle slack in the cable. helped a little but did not fix. the cable was all the way in.
I seen post that it wont shift till it was up to temp. I was thinking it was running cool. It sat about 1/4 up the gauge. The gob of gasket maker on the housing I was thinking it had no thermostat. (it did tho) got a new one in and now it sits cooler at about 1/8 up the gauge. I don't know it that's causing it to not shift.
plus when I sit at a red light brakes on the truck feels like its trying to hop/jump forward. THANKS FOR YOUR INPUT!!
My 92 22re does that. It used to be much worse until I adjusted the cable. Mine I think is stretched. Take a look at the Factory service manual online to see if it is adjusted correctly.
Here is the link:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Here is the link:
vanion2
Jul 29, 2015 06:17 PM
crashburnoveride
Jul 10, 2015 06:39 AM
