87 22R A/T wont shift 3 / O/D
Old Jul 20, 2014 | 05:32 PM
niceandeasy's Avatar
87 Toyota pickup 22R 220,000
Got truck from granddad when he passed away. just trying to get it back the way it was when I was a kid.
I have search with some help but no fix.
1st to 2nd shifts good, 3rd and O/D I have to let the gas go then it shifts.
I adjusted the (kick down) cable and its sitting now about half way with alittle slack in the cable. helped a little but did not fix. the cable was all the way in.
I seen post that it wont shift till it was up to temp. I was thinking it was running cool. It sat about 1/4 up the gauge. The gob of gasket maker on the housing I was thinking it had no thermostat. (it did tho) got a new one in and now it sits cooler at about 1/8 up the gauge. I don't know it that's causing it to not shift.
plus when I sit at a red light brakes on the truck feels like its trying to hop/jump forward. THANKS FOR YOUR INPUT!!
Old Jul 20, 2014 | 06:37 PM
slacker's Avatar
how long has it sat for ?
I would start by having the tranny flushed , you may just have a sticky valve
Old Jul 21, 2014 | 02:14 AM
It did not sit for long. Maybe 3mo. At the most. And I would never flush a trans that's just asking for more trouble. I may change the filter. But I don't think that's it.
Old Jul 21, 2014 | 05:22 PM
Bump bump
Old Jul 21, 2014 | 05:35 PM
JasonYota's Avatar
Shift solenoid could be going out. How does the fluid look? Have you changed it yet? These trans are pretty simple.
Old Jul 22, 2014 | 06:44 AM
Looks clean. And no burn smell. Looks like it was just changed not long ago
Old Jul 24, 2014 | 01:00 PM
I guess I will get not help from here
Old Jul 24, 2014 | 05:50 PM
skoob's Avatar
My 92 22re does that. It used to be much worse until I adjusted the cable. Mine I think is stretched. Take a look at the Factory service manual online to see if it is adjusted correctly.
Here is the link:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
JAmdor3
Aug 11, 2015 10:53 AM
vanion2
Jul 29, 2015 06:17 PM
crashburnoveride
Jul 10, 2015 06:39 AM
