87 -- 22r rebuild -- No Freaken WAY!!!
Old Oct 21, 2009 | 08:42 PM
larrys93pickup's Avatar
All,
a friend and I are rebuilding his 22r engine. We re-did the head, new head gasket, head job with new valves, everything was going smooth.
When I left the project, the truck was turning on, and staying on, but my friend needed to poor gas down the carb to get it started. So he had his dad rebuild the carb, and he swapped out the intake manifold, because the other one was leaking coolant from the bottom of the intake.
Anyway, fast forward to last sunday, we get the new rebuild carb back on the truck, and I noticed that the carb bolt, the long one that holds down the air filter was missing. Thinking that it dropped down, we took the carb off the truck and looked down the intake but just could not find the bolt.
He even purchased an adjustable magnet, and he checked, but could not find the bolt. He suspected that it was not inside the motor. He went ahead and purchased a new bolt, and finished putting the carb and intake back on.
This is where the No Freaken Way comes in...
When he starts the truck, this time, he is telling me that it is making a knocking noise, and he thinks that the air filter hold down bolt actually dropped down into the intake?
Do you think that this is possible?
I'm telling him no way, because the bolt is way too long, and it would have to get past the carb, intake runner, to get into the head.
What do you guys think? Are we screwed?
Let me know.
Thanks,
Larrys93pickup
Old Oct 21, 2009 | 08:45 PM
Jason4X4's Avatar
i knew a guy that sucked the air cleaner stud running down the highway, it was a 350 though, and it put a hole in the cylinder wall.
Windsor's Avatar
Time to pop the carb off and get a good look in the intake runners.
Old Oct 21, 2009 | 08:46 PM
Would the bolt be able to get past the valves on a 22r head?
Old Oct 21, 2009 | 08:49 PM
Windsor's Avatar
"probably not", but it could stick a valve open for the piston to smack against it.
Old Oct 21, 2009 | 08:51 PM
xxxtreme22r's Avatar
X2 on that. EFI no carb yes.
Old Oct 21, 2009 | 08:53 PM
How much damage would that cause, head fu%&-up? what about the piston, could I just replace one?
Old Oct 21, 2009 | 09:04 PM
i guess it would depend on how much it tore apart the piston in that short time frame, if it lodged something loose on a piston it could have tore up the cyl wall, the vavle seat in that cyl could be messed up if not the head surface. i would tear the head off and see what was going on and how much damaged there might be.
Old Oct 21, 2009 | 09:15 PM
Could I tell by removing the rocker cover and looking at the valve rockers?
What would I be looking for? a valve that is stuck in the down position?
Old Oct 21, 2009 | 10:01 PM
Windsor's Avatar
That would probably not be the best use of time. If you found a "stuck" valve, that's a teardown to get to the bolt. If you didn't see a "stuck" valve, that's a teardown to find the bolt through other means. Either way, it's a teardown.
If you had a "bore scope"-like tool, you can avoid some teardown by jamming it down things (intake runners, spark plug holes) and getting a good look.
Since they've mentioned a rattle and you're short a bolt, you need to get serious about finding it before starting up the engine again. Without the bore scope, start taking it apart (let the hunt begin).
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
_Nicco_
Sep 21, 2015 03:06 PM
shalom
Sep 8, 2015 10:02 PM
