86 22re
Old Nov 5, 2008 | 08:25 AM
YodaMan86's Avatar
86 22re
recently bought a 4x4 86 22re 133k miles i want to rebuild it and add a turbo any suggestions, without having to blow a ton of g's was thinking of a garrett t3, what mods should i do to the engine.
Old Nov 5, 2008 | 09:00 AM
scuba's Avatar
Welcome to YotaTech........
https://www.yotatech.com/forums/f120/how-search-73823/
Old Nov 5, 2008 | 12:37 PM
YodaMan86's Avatar
was kinda hoping someone could give me advice without reading what others asked :\
Old Nov 5, 2008 | 05:52 PM
abecedarian's Avatar
how much boost you wanna run?
Old Nov 6, 2008 | 05:25 PM
YodaMan86's Avatar
around 5 or so is fine i herd the garrett t3 is good but what mod's and things will i have to do to the 22re?
Old Nov 6, 2008 | 05:35 PM
the stock 22re ECU and engine block should be able to compensate for about 5-6 PSI boost, if you draw through the stock AFM and have no vacuum leaks and retard the timing appropriately. You'll prolly see only about 30 hp (at best) over stock though. You'll likely be retarding the timing too much to realize as much power as is possible from the setup though.
Unfortunately, the stock 22re ECU is not capable of dealing with much more airflow over stock, so an aftermarket air/fuel/timing management solution would be worth the cost.
Old Nov 6, 2008 | 07:14 PM
YodaMan86's Avatar
what would you recommend with the rebuild of the engine to manage more then 30 hp of the turbo and pickup more power for around $3 grand or less, name what you would do.
Old Nov 10, 2008 | 07:02 PM
YodaMan86's Avatar
anybody?
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
