86 22r Carb not taking fuel
Old Dec 3, 2012 | 06:33 AM
dlott33's Avatar
My 4wd has been running great till this morning now the only way I can get it to start is by pouring gas in the carb. Runs till gas is gone then dies. Pulled the line from the pump to the carb and it's getting fuel to the carb. Sight glass on carb is empty. What should my next step be?
Thanks
Old Dec 3, 2012 | 07:01 AM
dlott33's Avatar
Tapped on the fuel cut solenoid and she fired right up
Old Dec 3, 2012 | 07:02 AM
westjohns yota's Avatar
are you sure its producing enough fuel? try replaceing the pump anyways, its 26$ and you can take it back if it doesnt work, i dont see how it couldnt take fuel honestly....
Old Dec 3, 2012 | 01:52 PM
slow-mo's Avatar
Since the sight glass did not show any fuel, the issue was a stuck float needle valve. That prevented any fuel from entering the flaot bowl. Tapping on the fuel cut solenoid caused the needle valve to dislodge.
Old Dec 3, 2012 | 04:59 PM
dlott33's Avatar
Thanks for the info.. Hopefully it won't do it again. I really don't want to pull the carb apart.
Old Dec 3, 2012 | 10:43 PM
Mr.Utah's Avatar
I would trust slo-mo anyday with a carb, his posts have helped me out significantly.
Old Dec 4, 2012 | 12:35 PM
xcfunrunner's Avatar
I agree with Slow-Mo. If he hadn't said it, I would have. If it happens again, I would go in there and clean it all out with carb cleaner. I had this exact problem on my old dirt bike. It uses a similar system when talking about the float bowl. Just pull it apart if it happens frequently and clean everything out of there.
Old Dec 4, 2012 | 03:17 PM
dlott33's Avatar
I'll do it...Thanks
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
