4runners and trucks with 33x12.5 inch tires
Old Aug 10, 2008 | 11:17 AM
tman12345's Avatar
can you show me some pics, i wanna see how much they stick out the side. Is 3.75 the correct backspacing for BJ spacers/coil lift?
Old Aug 10, 2008 | 02:45 PM
91 4Runner's Avatar
As for sticking out/backspacing/lift - I don't know. But No lift/stock rims they are about 1.5" to 2" outside the fender.
Old Aug 10, 2008 | 03:08 PM
yotAddiction's Avatar
33x12.50 Baja Claws on 10" rims
Old Aug 10, 2008 | 05:37 PM
woodendude's Avatar
http://s296.photobucket.com/albums/m...t=SSCN3678.jpg
Old Aug 11, 2008 | 08:59 AM
tman12345's Avatar
is that lifted? what are the specs on the rims?
Old Aug 11, 2008 | 11:41 AM
woodendude's Avatar
not lifted and I do suffer some rub when in reverse fully turned. Stock toyota rims.
Old Aug 11, 2008 | 02:07 PM
SLOWBOOST's Avatar
35's are in my sig.
Old Aug 11, 2008 | 07:32 PM
Blackulua's Avatar
Heres my truck that is set up with 1" RB body lift ,1.5" BJ lift,rear shackle lift and front diff drop.The inner fender and front valance clears on the turn without rubbing issues.My tires is 33 x 12.5 on 15 x 10 MT classic II's and you have to google it up on the backspacing but the tires stick out for sure.Im running 4:88 Precision gears and the truck runs really smooth easy on the hills on fourth gear. Im running my TG ceramic clutch and it feels soft on the pedal but really grabs on the shifting.
Old Aug 15, 2008 | 01:13 PM
affmondo22's Avatar
do you need to have a larger backspacing to fit 33/12.5's with a 3 in body lift?
Old Aug 15, 2008 | 01:16 PM
904_runner's Avatar
I think the only reason you need 3.75 backspacing is with a bracket lift. Don't take my word on it, thats what i think.
Here is my 4runner with 33X12.50's and a 4" bracket lift
Old Aug 15, 2008 | 02:18 PM
olharleyman's Avatar
35x12.5's not 33's but still the same width and look as the 33's on 8" rims and 3.75 backspacing 4" bracket lift and as far as I know you need the backspacing only for the bracket lift I maybe wrong on that but I belive it is correct.
Old Aug 15, 2008 | 03:23 PM
abecedarian's Avatar
you need 3.75" backspacing, or less, with any IFS bracket type lift.
this is because of the extension that bolts to the steering knuckle which raises the upper control arm in relation to the axle centerline. without the more shallow backspacing the inner lip of the rim will grind on the end of the upper control arm.
they are not absolutely necessary with ball joint spacers, but will help the appearance of the vehicle- give it a slightly wider stance.
Old Aug 15, 2008 | 04:06 PM
eighty5yota's Avatar
i pulled my fenders out a bit by hand.. home-made(ish) well a cop was givin me crap sayin my tires stuck out a 1/4 inch past the limit, so i yanked on em and he left. i kinda like it!
Old Aug 15, 2008 | 04:29 PM
Jay351's Avatar
Yes, If you run bj spacers OR a bracket lift 3.75" wheels is needed. Only if you want to run a wide tire. If you run a pizza cutter you would be fine with stockers.
I got tons of pics of my ride on my cardomain. Wheels have 3.5" backspacing.
Old Aug 15, 2008 | 04:31 PM
all in all, a GREAT LOOKING BUNCH OF 'YOTAs
... well except for that one next to the truck in yotAdicction's first pic... oh wait, that's a jeep... that explains it.
Old Aug 15, 2008 | 10:19 PM
forbiddenera's Avatar
33x12.5 no lift..not a good idea
Old Aug 15, 2008 | 10:57 PM
muddpigg's Avatar
My old springs, Downey 3", I think the BS is 3 3/8".
Old Aug 16, 2008 | 12:43 AM
dropzone's Avatar
Fossilized
Originally Posted by 904_runner
OT, but that is quite the interesting tread pattern..
Defy Concealment
Oct 29, 2020 11:01 AM
voiddweller
19
May 2, 2016 09:10 PM
bowhunter1640
Jul 6, 2015 08:10 PM
bobbybouche
Jun 18, 2015 10:22 AM
