4Runner rear window sweep
Old May 12, 2020 | 04:56 PM
keycw's Avatar
5 Year Member
The rear inner window sweep on my 87 4Runner is starting to come apart. I have a new set of clips but the sweep is discontinued. Has anyone tried maybe using a second gen sweep or have another solution?
Old May 12, 2020 | 05:12 PM
Melrose 4r's Avatar
5 Year Member
I’m interested also. Could be your next product offering Keycw?
Old May 12, 2020 | 06:19 PM
wallytoo's Avatar
i’d be interested in an outer...
Old May 12, 2020 | 06:53 PM
keycw's Avatar
5 Year Member
the outer is still available last I checked
Old May 12, 2020 | 07:06 PM
keycw's Avatar
5 Year Member
From this drawing it looks like only the outer window seal uses the plastic clips on a second gen. The first gen uses the clips for both inner and outer. Can anyone with a second gen verify this?
Old Jun 7, 2020 | 09:34 AM
keycw's Avatar
5 Year Member
Been a while but I found a good part to use for a replacement. The outer sweep from 2nd gen runners works. I pulled an inner and outer from a local yard for testing. The inner on second gens doesn’t use the plastic retainers, it used bendable metal tabs, so it doesn’t work. The outer is the proper length, and uses the same plastic retainers. Works great. I used a used part but I looked up the drawing and it appears to be available new for 28.50 P/N 682-89101 and you’ll also need the plastic retainer clips 68211-89113.
cjstephens
Nov 5, 2007 07:18 AM
LegendofJake
May 14, 2007 05:56 PM
94toyota4x4
Sep 28, 2006 05:38 AM
Goose
Dec 11, 2003 06:37 PM
