4Runner rear window motor.
Old Feb 1, 2010 | 09:38 PM
myyota's Avatar
I need to replace the tail gate window motor on my 86 4Runner, and from what ive read here the window motors in the doors are the same, but will a window door motor from a second gen 4Runner (90-95) work to replace the motor for my rear window ?.
Old Feb 2, 2010 | 01:28 AM
91 4Runner's Avatar
Yes they are the same. Just make sure you get the drivers side.
Old Feb 2, 2010 | 05:17 AM
90runnerfan's Avatar
is that true with the second gen 4runner rear window as well?
Old Feb 2, 2010 | 08:14 AM
874runnersr5's Avatar
i though it was only passengerside door? or was it drivers? hmm..
Old Feb 2, 2010 | 04:58 PM
myyota's Avatar
So it has to be the driver side motor only ?, the passenger side window motor won`t work ?.
Old Feb 2, 2010 | 10:38 PM
hiltu's Avatar
subscribed for answer
Old Feb 3, 2010 | 12:38 AM
91 4Runner's Avatar
When I replaced mine on my 2nd gen I got it from a drivers door on a Camery. All the research said driver side passenger.
https://www.yotatech.com/forums/f116...ptions-166624/
The motor has to be orientated like this...
Old Feb 3, 2010 | 07:58 PM
myyota's Avatar
Ok, so i can use a window motor from a 4Runner or camery, from the driver side of either vehicle, and it can be from the drivers door or passenger door. Im going to try and find one from a rear door because it will have alot less use than the drivers window.
Old Feb 3, 2010 | 08:11 PM
daveb704's Avatar
whats up ,yes it will have less use have u thought about how much a rear window weigh's compared to a front camry/ less than 1/2 check on a after market at ur local parts house dont offten tell any one this but the motor after market will run same as junk yard insure you look the regulator over and greese good to in clude the tracks in door and window frame will make a mess will add muey life to motor this is my 6 1gen and i work at a toyota store as a tech
Old Feb 4, 2010 | 12:24 AM
91 4Runner's Avatar
All the Right hand side motor part # are the same...
Old Jul 30, 2010 | 05:54 PM
georghammond's Avatar
Do you think this little camry trick will work on 1st gen 4runners? Need to replace rear window motor on an 84 4runner.
Old Jul 30, 2010 | 06:36 PM
myyota's Avatar
Yes, it will work.
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
