4runner ifs problem i think please help
Old Nov 8, 2007 | 05:50 AM
AndYota's Avatar
I'm pretty sure there several hub-type options on the 93 depending on trim level. Can you get a pic of the hub posted? that might help.
Andy
Old Nov 9, 2007 | 01:19 PM
wncmtnrunner's Avatar
their the Add
Old Nov 26, 2007 | 09:17 AM
8yota9's Avatar
Im not tryin to jack the post but... i have just goten home from a little wheeling and now my cv shaft is acting weard. the end that conects to the diff has a lot of in and out play ao much that when i turn it slides out a little and the bolts are smacking the truss . is this a bad cv or is my ifs fu**ed?
Andrew
Old Nov 26, 2007 | 09:19 AM
DeathCougar's Avatar
Sounds like the C-clip fell out, or you broke something. And that would be bad. Take it apart and fix it!
Old Nov 26, 2007 | 09:21 AM
  #25
8yota9's Avatar
What C-Clip? the one in the outer hub were the cv shaft ends or is it in the diff
Old Nov 26, 2007 | 09:33 AM
  #26
The diff has a jack shaft that the CV axvle bolts to. A c-clip holds that jack shaft into the diff. If that C-clip comes off or breaks, the CV is still bolted to the jack shaft, but now they move as one unit and it will pull the jack shaft/cv axle assy out of the diff.
Old Nov 26, 2007 | 09:49 AM
  #27
8yota9's Avatar
ahhh yes i think that is the problum. that shaft has play the jack shaft its pulling everthing out tward the wheel.is this a verry intens job? can i still drive my truck? im so sic of ifs its killing me.every problum i have seems to be with that damm front end. thanks alot
Old Nov 26, 2007 | 09:58 AM
  #28
Belize Off Road Team's Avatar
mine just today started clicking on the passenger side front wheel area too, im gonna look at the boot
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
