4runner ifs problem i think please help
i have a 93 with discos and recently when i turn in 4wheel a knocking or clicking ocurs it sounds like it is coming from the driversside
it happens only in 4WD?
yeah only when its in 4wheel and in hi it does a more repetative sound than in lo but it drives fine please help
do you have manual locking hubs?
most likely your axles toastt
Sound like your CV joint is broken.
Check out the boots covering the axle, if you see a rip you should replace the joint. |
cv's i would bet as well
i was thinking CV's too but shouldn't it still make noise in 2wd if he has drive flanges?
if he has manual hubs, the axle doesnt spin, therefore only in 4wd
Seems to me that it could be one of two things wheel bearing or Axle shaft. I have done all four bearings in my truck. The ones in the front only made noise when I ran it in four wheel. When they got really bad they sound like a meat grinder all the time. On the plus side if you have to do the axle shafts they it would be easy to replace the wheel bearings at the same time.
To check the axle shaft just reach thru the wheel well and shake the axle shaft like you were checking the play in a drive shaft side to side, up and down, and back and forth. Any excessive play is a good indication that they are worn out and need to be replaced. Oh yeah if you do need to replace them then there is a good chance that the lower ball joints need to be removed to do it. let us know how it works out |
my 93 4runner was recently doing the same thing clicking and knocking in 4wd i though it was the cv and i replaced it only to find out that my ring and pinion gears were completely stripped so u should drain ur front diff fluid and see if there is metal in it
thanks for all the replys i sounds like ill have to be fixing that
but the fact that it does it only when i turn does that meen something diffrent
Clicking noises from CV joints when turning sounds like a classic worn CV to me. Now don't necessary get too worried, I have seen cars drive for 50,000 miles on clicking CV joints. If you can make it go away by unlocking the hubs I'd just get a used shaft and keep it handy.
Checking for worn parts like bearings is never a bad idea but your symptoms really sound like worn outer CV symptoms to me. Frank |
i have the auto hubs what do i do and how much do cv joints run
auto hubs or a.d.d
If you have auto hubs, I'd first convert to manual hubs. If you have ADD and want to keep it, then yeah you need to look at a half shaft. Check the boards for used ones or you can just call your local parts store for a reman.
Frank |
cvs for go for like $80 but they have like a $90 core charge
I got a pair of new shafts for $140 without a core. They're Napa, but I've done some pretty good wheelin' since and they've held up really well.
Andy |
their what ever 93 4runners came with and they squeak when i go down the road i need the cheapest fix
