3vze HHO
Old Aug 25, 2020 | 09:24 AM
Gregery's Avatar
Originally Posted by millball
Ever hear of the 'Laws of Physics'??? Where do you rekon the energy to make this HHO is going to come from??? No free lunch.
The sun has been fusing Hydrogen atoms creating Helium atoms and shooting off electrons creating intense levels of free photons since before Earth was created. Supplying heat and energy to all life on earth without ransom for millions of years... ... "Without ransom" kinda means Free.
Old Aug 25, 2020 | 09:33 AM
millball's Avatar
Alright, let's see you do what the sun does. 237.13 kj per mol to crack water.
Methinks something more economical might be done with those joules.
Old Aug 25, 2020 | 09:50 AM
MaK92-4RnR's Avatar
I'm blown away the thread has made it this far.
You guys are discussing a hydrogen fueled 3vze. Pretty sure Doc Brown's Delorean is a better idea at this point and that idea is strictly Hollywood.
Old Aug 25, 2020 | 09:53 AM
Dr Phat's Avatar
Bruh, you dont even understand this big (wet) brain thinking. Were putting a ˟˟˟˟˟˟˟ SUN in a 3VZE.
Old Aug 25, 2020 | 10:15 AM
  #25
MaK92-4RnR's Avatar
lmao. Putting a whole lot of time wasted into a 3vze.
Old Aug 25, 2020 | 10:24 AM
  #26
wallytoo's Avatar
i am very familiar with carbureted vehicles, and own three right now. my ‘75 cj5 with a 258 with a weber k551 32/36 dgv, my ‘48 dodge 1.5-ton dump truck with 1 bbl carter ball & ball, and my ‘52 ford 8n with marvel schebler updraft. i’ve owned the cj for 27 years, the truck for 13, and the tractor for 11. they all run very well, idle perfectly, and give acceptable, reliable service (the carbs, if not the vehicles).
Old Aug 25, 2020 | 11:50 AM
  #27
scope103's Avatar
"HHO" was a popular topic about 12-15 years ago. The idea was to use alternator current to electrolyze water into Hydrogen and Oxygen, and then inject that into the fuel stream to get amazing improvements in fuel economy. Obviously, it's not that hydrogen is replacing gasoline, rather, the argument went, a tiny amount of hydrogen in the intake (and a boat-load of electronics to over-ride the ECM) would allow your run-of-the-pump gasoline to burn 12-20 (to 100) percent more efficiently.
Did it work back then? Probably not, but science can be discovered in someone's backyard just as well as in a laboratory. Careful experimentation can lead to incredible breakthroughs. Would it work today? No car today uses HHO. So far as I'm aware, there are no billionaires who made their mark with HHO. There are still people out there who will sell you an HHO generator, but somehow I would expect it to have gone more mainstream in 12-15 years if it really worked.
But if you want to try it, I can't see any reason not to. I'd figure hundreds of thousands of dollars and many years, but if you can pull it off then you will be that billionaire.
Old Aug 25, 2020 | 04:18 PM
  #28
Co_94_PU's Avatar
Originally Posted by scope103
"HHO" was a popular topic about 12-15 years ago....
It's gone a bit farther than that, let's run a double battery system unregulated and generate five liters of gas per minute..
It's super duper unsafe to run an IC engine on this stuff which is why they went with PEM electrical generators on the very few fuel cell vehicles.
Old Aug 25, 2020 | 04:21 PM
  #29
Gregery's Avatar
Maybe the mainstream doesn't want it that way... what's to sell you, when you have a car that runs so much more efficently? Maybe so they make the HHO people out to be crack pots, and deny the viability.. and that's usually easy, because the HHO crowd generally kinda are a little tweaked.
But look at Tesla, he was made out to be a crack pot. And all his fame was earned posthumously, some of the things he invented was stolen by a more famous name. Yet his arch nemesis who didn't hardly invent anything, we still remember, as one of the great inventors. He filed and kept all the inventions of his worker/students under his own name and kept the patents in case someone else came up with a similar better idea... and he'd sue, even if his idea didn't work.. killing some possible great ideas for money.
Many of those patents are far more rediculous and preposterous is than Tesla's were.. so.. .. .. who was the real crack pot?
Follow the money.
Old Nov 9, 2020 | 11:18 AM
  #30
4runner4days's Avatar
Gregery, how's your HHO project coming along? I'm very interested! Glad to see there are other 3vze owners thinking about on-board HHO air optimization. Rather than trying to reinvent a carburetor, would simply tweaking the O2 sensor/signal work for your application?
That's different. That would be a full-on hydrogen conversion, and it's already successfully been done many times. Here's a study by the ASEE where they converted a 3.0 V6 Sienna:
https://www.asee.org/file_server/pap..._3-12-2012.pdf
mike250
Jul 30, 2016 10:50 AM
never2fast
May 23, 2014 01:43 PM
milkybar
Mar 18, 2014 12:23 PM
marshm4ll0w
Aug 14, 2009 09:16 PM
Skydigger
Dec 10, 2002 04:23 PM
