3vze engine problems??
Old Jul 9, 2009 | 06:44 AM
tj7mwr's Avatar
haha i need to show u guys a picture on how all me vacuum lines are held on sombody zip tied them all on so i need to buy a crap load of hose clamps. i was pullin a plug and a big vacuum line just fell off and it ran that much worse. But i dont think thats the whole problem but it will help ALOT
Old Jul 10, 2009 | 04:10 PM
tj7mwr's Avatar
Unhappy
[IMG=http://img14.imageshack.us/img14/5233/4runneru.jpg][/IMG]
Ok the compression is ok. So i checked the cams, and there fine.
So i tested the injectors. There all firing. WHAT ELSE COULD IT BE
Old Jul 13, 2009 | 12:31 PM
yota addict's Avatar
have you fixed the vac line going to the fuel pressure regulator?
Old Jul 19, 2009 | 06:35 PM
tj7mwr's Avatar
Once i get my gasket set in and put it back together then i will start checking the vacuum lines. Most were held on with zip ties so that might be it.
Old Mar 3, 2011 | 11:03 AM
  #25
six6vetteguy's Avatar
low compression
You probably solved this issue a long time ago, but it is your valve adjustment...these cars need a valve adjustment every 60K miles. That's why your compression is low on all cylinders....should be 145-170 psi on the 3VZe motor.
Old Mar 3, 2011 | 11:17 AM
  #26
blake.nemitz's Avatar
i bet when you fix your vac lines properly it will go away
Old Nov 27, 2012 | 09:44 AM
  #27
jrridings's Avatar
similar issue...I found a disconnected hose
It connects at the Gas Vapor return canister on the left rear of the engine bay. The one connected that is the return is properly connected. The other rubber tube is free hanging in the engine compartment. I recently replaced the heater bypass tube on the 3.0 located on the rear of the engine. My Manual I purchased does not show where to look to connect it. I do smell fuel faintly....I think I saw a diagram showing that it connects just next to the heater bypass...any pictures/diagrams/or links anyonie can toss my way would be awesome....
1990 V6 3.slow automatic with 279k (100 since rebuild) 12k on rebuilt Transmission....
Old Nov 27, 2012 | 10:28 AM
  #28
scope103's Avatar
(ignore the arrow).
You probably broke off one of the nipples on the Thermal Vacuum Valve (look inside the free end of the hose). Do a search here and you can find people who have successfully fixed it, or just shell out $55 and replace it. (Yes, that is the source of the fuel smell.)
Old Nov 27, 2012 | 10:30 AM
  #29
scope103's Avatar
(ignore the arrow).
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
