3vze complete exhaust
Old Sep 15, 2010 | 09:29 PM
  #341
MaK92-4RnR's Avatar
just buy a budbuilt skid plate with the belly pan, it'll be fine.
Old Sep 19, 2010 | 06:26 PM
  #342
BeenYota's Avatar
3vze ERG valve
Old Sep 19, 2010 | 06:29 PM
  #343
91_TOYOTA_4x4's Avatar
Originally Posted by MaK92-4RnR
it's backkkk
how did i miss this????? freaking awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! mak you need another exhaust video
Old Sep 19, 2010 | 08:06 PM
  #344
MaK92-4RnR's Avatar
it was put back on along time ago. lol and videos of pismo will be coming eventually.
Old Sep 19, 2010 | 08:09 PM
  #345
haha obvs but i missed it lol k good wish my 3vze was worth keeping so i could run your exhaust next year if i go 3.4 its getting full exhaust and that borla heh. whens the SAS happening?
Old Sep 19, 2010 | 08:10 PM
  #346
MaK92-4RnR's Avatar
lol SAS is just an idea... probably wont happen.
Old Sep 19, 2010 | 08:14 PM
  #347
haha you should just do it! do a 3" front and make the front hanger up higher and shorter shackles, low profile bump stops and run your 33"s . like Vance said when he sas'd, he could just point it somwhere and it would go right over it without lockers even :O will be so sick haha
Old Sep 19, 2010 | 09:09 PM
  #348
mbomberz1's Avatar
hey guys i had a question, is there any flex pipe on the 505s? iv been waiting for mine for 2 and a half months now. And still not sure when they are going to arrive. Last thing i heard was they were waiting on flex pipe..
Old Sep 23, 2010 | 03:43 AM
  #349
bigliltruck's Avatar
glad to see your willing to learn and do your own wrenching even though your not that experianced, its a great thing to learn and there is nothing like doing your own work. Don't mind kawasaki his hour exhaust system probably consists of a dryer vent hose and some pvc. my compliments man, keep up the good work
Old Sep 23, 2010 | 06:33 AM
  #350
MaK92-4RnR's Avatar
lol Kawasaki is a RL friend of mine. Has been since i was like in 10th grade. I know he's just bustin my balls, so no biggie.
Heres a small update:
3 of the headbolts backed out yesterday! I had them replaced with factory head bolts but man, the exhaust leak was massive... Had to replace the gasket too as they were burned up. Valves are fine as well
Old Oct 2, 2010 | 10:32 AM
  #351
elkinsen's Avatar
hey man i am doing this install right now and i have come to the part of connecting the reed valve to the headers and its not lining up at all so i guess im just wondering if you had a problem with this and if so how did you do it. thanks in advance
Old Oct 2, 2010 | 10:34 AM
  #352
MaK92-4RnR's Avatar
I'll need some pictures.
Old Oct 2, 2010 | 10:53 AM
  #353
elkinsen's Avatar
ok so i tried to post a pic but it said it failed. but all it is is the copper tube going from the reed valve straight to the header
Old Oct 2, 2010 | 10:59 AM
  #354
MaK92-4RnR's Avatar
the copper tube is straight junk... but the only way to get it to work is unbolt the reed valve, put the reed valve on the copper tube, and call it good. the valve will be loose at this point, but it'll be functional still. the only way to get it to bolt to the block, is to get a flex hose like the EGR valve.
Old Oct 2, 2010 | 11:02 AM
  #355
elkinsen's Avatar
that's what i figured but i just dont understand why they would send that if it doesn't work. ok well thanks for being the bearer of bad news lol. thanks for your time man
Old Oct 2, 2010 | 11:17 AM
  #356
MaK92-4RnR's Avatar
it wont hurt anything, I ran it like this for awhile. and it did fine. just be sure to find a hose. I used the one off my stock manifold. cut it off, and put it on.
Old Oct 2, 2010 | 12:05 PM
  #357
elkinsen's Avatar
ya i would but i had to cut the hell out of that thing just to get it off. the threads were rusted on there.
Old Oct 2, 2010 | 12:13 PM
  #358
MaK92-4RnR's Avatar
lol nice.
Old Oct 2, 2010 | 05:11 PM
  #359
elkinsen's Avatar
ok so i took your advice about unhooking the reed valve so now its just hanging there it looks like it should be good so thanks for that. i have one more ? though, did you have any problem with the piece of exhaust pipe with the o2 sensor hole in it the flange to bolt on the o2 sensor is welded off center so that the nut will not screw on to the bolt , it might just be mine so im going to call and see if they will send me a new one. i hope they do
Old Oct 2, 2010 | 05:56 PM
  #360
mbomberz1's Avatar
elk, i had the same probs your talking about. For the o2 sensor, i just ground down the side/corner of one nut so it would slide in far enough for the bolt to thread thru. Also works to hold the nut so you only need 1 wrench to tighten
